idle problem gone bad!! ! ! !
Old Aug 5, 2003 | 06:24 PM
dvcart106's Avatar
Default idle problem gone bad!! ! ! !
ok at first my car was reving up when my car was at idle but there was no check light and the car was still drivable. so i decided to go and snoop around the tb. i took off the throttle position sensor and when i put it back on and started the car it rev hella high. at first it was at 5000 rpms. so i turned off the car and adjusted the tps around and tried it again. this time it revved up to 4000 and the check light went on again! whats the problem now! ???? need help please! ! !
Old Aug 5, 2003 | 09:02 PM
dvcart106's Avatar
Default Re: idle problem gone bad!! ! ! ! (dvcart106)
93 civic hb wit 94 B18C
Old Aug 6, 2003 | 06:20 AM
EE_Chris's Avatar
Grab a multimeter. Re-adjust the TPS so that its output is .45v @ idle and then reset the ECU.
Old Aug 6, 2003 | 08:41 AM
1bad-eg's Avatar
Default Re: idle problem gone bad!! ! ! ! (EE_Chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris &raquo;</TD></TR><TR><TD CLASS="quote">Grab a multimeter. Re-adjust the TPS so that its output is .45v @ idle and then reset the ECU.</TD></TR></TABLE>
J_Trez
Apr 29, 2005 04:46 PM
wolf3007
Mar 26, 2004 05:06 AM
quik2kSi
Dec 27, 2003 09:04 AM
OneFastGsr
Oct 8, 2003 08:30 AM
maxpsi
Jan 16, 2003 12:51 PM
