idle problem
idle problem
my 97 dx(stock) has this idle problem were after i start it idles high until warm them starts to idle normal then drop to the point of almost shuting off only to go back then fall again. i had a friend use his code reader and it came up as a bad map sensor i replaced it but the problem is still there, can anybody help me?
Modified by J_Trez at 1:24 PM 4/29/2005
Re: (Jimmy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jimmy »</TD></TR><TR><TD CLASS="quote">Reset your ecu, could be your IACV, or you may just need to adjust your idle.</TD></TR></TABLE>
I'm having the same type of problem on my EJ8. IACV stands for Idle Air Control Valve? Where is this located? Could it also be that a bad TPS throws a code for a bad MAP?
immalooser
02-18-2009 05:23 AM
mikeunreal2
03-29-2006 09:27 PM
