11.1-11.5cr + 150shot direct port nitrous on pump gas....safe??
Old Aug 5, 2003 | 05:29 AM
GOLDBERG's Avatar
Default 11.1-11.5cr + 150shot direct port nitrous on pump gas....safe??
forged internals
darton sleeved
msd digital 6 to retard timing
colder plugs
stock injectors?
anyhow would setup be safe?
Old Aug 5, 2003 | 06:28 AM
Turbocivic94's Avatar
Default Re: 11.1-11.5cr + 150shot direct port nitrous on pump gas....safe?? (GOLDBERG)
It would be safe but I would do dual stage. Just dont forget to retard ur timing.
Old Aug 5, 2003 | 06:54 AM
falcongsr's Avatar
What is this crap?
yeah that should definitely make it down the strip 3 or 4 times.
Old Aug 5, 2003 | 09:00 AM
Drag_Dc2's Avatar
Default Re: 11.1-11.5cr + 150shot direct port nitrous on pump gas....safe?? (falconGSR)
Why risk the chance of blowing when race gas is readily available at the track?
I ran 11:2-11:4 compression with a 50 shot and ran 100 octane with a slight hint of detonation.
the timing was set at 10 degrees, I used heat range 7 copper plugs, and I dumped crazy amounts of fuel that the car would constantly flood off the n2o. Still after every pass my plugs would have some metal dust particles on them.
Old Aug 5, 2003 | 10:40 AM
tygsr's Avatar
Default Re: 11.1-11.5cr + 150shot direct port nitrous on pump gas....safe?? (DragEg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DragEg &raquo;</TD></TR><TR><TD CLASS="quote">Why risk the chance of blowing when race gas is readily available at the track?
the timing was set at 10 degrees, I used heat range 7 copper plugs, and I dumped crazy amounts of fuel that the car would constantly flood off the n2o. Still after every pass my plugs would have some metal dust particles on them. </TD></TR></TABLE>
Why only 100 octane. If I was running that kind of compression with nitrous I would go at least 110, probably 112. Your car will run safer and better. Why risk engine damage on shitty pump gas??
Old Aug 5, 2003 | 11:20 AM
Drag_Dc2's Avatar
Default Re: 11.1-11.5cr + 150shot direct port nitrous on pump gas....safe?? (tygsr)
100 octane was the highest level of unleaded i could obtain at the track. Heck i would run 118 if i wasnt afraid to burn out the o2.
I am from cali, the highest pump gas we get is 91. Unfortunately 100 octane isnt considered pump gas here.
But you are right, I should just said F*ck it who cares about a measly 02 and ran 118 and break into the 11s!!!
Old Aug 5, 2003 | 05:24 PM
boosted3g's Avatar
i think its totally fine to run leaded in our cars just not for a very long time. I ran it all the time in my teg when it was street legal but i only put about 2k on a year. Nothing but c12 or c16, never burnt up an 02. I did however periodicly spray it with some brake cleaner.
Old Aug 5, 2003 | 07:41 PM
GOLDBERG's Avatar
Default Re: 11.1-11.5cr + 150shot direct port nitrous on pump gas....safe?? (boosted3g)
what about a 100 shot on pump gas?safe??how much timing should i yank with the msd digi 6.... 6?
B-motor
Nov 8, 2006 09:18 PM
ITR981002
Apr 27, 2005 08:51 AM
ninja8oi
Nov 21, 2003 12:53 AM
lsteggy
Dec 17, 2002 04:01 AM
pstreck
Aug 17, 2001 01:42 PM
