swaping GSR dizzy into h22 dizzy problem
Old Aug 2, 2003 | 06:07 PM
F120man's Avatar
New User
Default swaping GSR dizzy into h22 dizzy problem
i know that the internals of both dizzy are compatible. i took a comparison between the both distributors and there is room for the GSR dist. stuff to fit into the prelude dizzy. so i began working on it today, the problem is that i cant remove the center "rod" which has a round bearing like on it, i belive this is keeping me unable to remove the large plate and all of the interal contents. to even make things more troublesome, i even stipped some of the screws thats inside the prelude distributor. to make things quick, i cant swap out the interals of both distributors, it seems too much of a hassle to do. does anyone know how i can handle this distributor problem? im sooooooo close to finishing the h22eg swap.
Old Aug 2, 2003 | 06:47 PM
CvexH22's Avatar
Default Re: swaping GSR dizzy into h22 dizzy problem (F120man)
Remove the Ring clip around the shaft the part that goes to the cam, so that piece can be remove. then 3 screw that holds the shaft from the inside...quite simple i swap it out with my sohc dizzy... but you have to use the h22 shaft
Old Aug 3, 2003 | 11:24 AM
F120man's Avatar
New User
Default Re: swaping GSR dizzy into h22 dizzy problem (CvexH22)
thanks alot!, that **** was giving me a major headache
marcusgnf
15
Mar 30, 2008 04:25 PM
JohnD1079
Nov 26, 2007 01:30 PM
fabe85
Jun 27, 2007 03:33 AM
djsire
Mar 21, 2006 05:34 AM
93H22ACX
May 24, 2004 02:32 AM
