Who Here has swapped Dizzy Distributor Internals?
Old Nov 23, 2007 | 08:11 AM
JohnD1079's Avatar
Default Who Here has swapped Dizzy Distributor Internals?
ok, who here has swapped Dizzy internals or taken one apart?
How do you take out the most bottom Sensor? I cant seem to find a combination of differnt moves and angles to get that thing out of there. Ive taken apart and reasembled it like 3 times, but i have never been able to take that one out(meaning i tried 3 times).
Is there some sort of trick to get that top plate off. I know there are 3 screws holding it underneath, but how do you get to them?
There has to be something im missing here. Im worried that when i dissamble my good dizzy for the internals, im gonna bang up the sensors and theyre not gonna work.
H22/3 OBD I Dizzy. Swapping internalls with a F22 Dizzy
Old Nov 23, 2007 | 03:12 PM
mmuller's Avatar
Mad Scientist
Default Re: Who Here has swapped Dizzy Distributor Internals? (JohnD1079)
to get to the bottom sensor you have to take the shaft off, 3 bolts and gear on the other side
Old Nov 24, 2007 | 09:59 AM
JohnD1079's Avatar
Default Re: Who Here has swapped Dizzy Distributor Internals? (mmuller)
ya, but how do you get a screwdriver to the other side. There is a like no room whatsoever. No even a little stubby screwdriver will fit in there
Old Nov 24, 2007 | 10:07 AM
mmuller's Avatar
Mad Scientist
other side of what?
Old Nov 26, 2007 | 01:30 PM
JohnD1079's Avatar
never mind, i got it the shaft off. Did know you could.
http://www.cb7tuner.com/vbb/showthread.php?t=88245 is where i got it from. I hope this helps someone
BseriesEKhatch
Apr 25, 2014 05:43 PM
EGPHANTOM
Nov 30, 2004 07:27 PM
TooDrunk2See
Oct 5, 2003 03:46 PM
F120man
Aug 3, 2003 11:24 AM
