Turbo w/ light flywheel or not?
Old Aug 2, 2003 | 12:45 AM
HYREV2NR's Avatar
Default Turbo w/ light flywheel or not?
OK here's the?. I'm going turbo in the future & would like to know if I should install a lightweight flywheel when I go to give the car a better clutchfor the extra load? I've been told to leave the stock f/w on the car by someone who has a pretty strong turbo car himself. I just want to know the reason behind this. Of course you wouldn't want to change the final drive to a lower ratio but why wouldn't you want to lighten the load on the crank?
Old Aug 2, 2003 | 07:12 AM
falcongsr's Avatar
What is this crap?
Default Re: Turbo w/ light flywheel or not? (HYREV2NR)
are you the guy on that show Hi Rev Tuners? I LOVE that show!
if i send you a pic of my car will you autograph it?
Old Aug 2, 2003 | 08:47 AM
HYREV2NR's Avatar
Default Re: Turbo w/ light flywheel or not? (falconGSR)
Eh sorry, wrong person. But I do autogragh paychecks regularly.
Old Aug 2, 2003 | 08:52 AM
thrty8street's Avatar
bump.
Old Aug 2, 2003 | 09:29 AM
deepgreengsr's Avatar
Default Re: Turbo w/ light flywheel or not? (thrty8street)
yes lightweight flywheels always help. GET it.
Old Aug 2, 2003 | 10:33 AM
Foozball26's Avatar
Default Re: Turbo w/ light flywheel or not? (deepgreengsr)
They don't always help, you can go overboard, I'd stick with around a 12 lb flywheel, any lighter than that and you lose the rotating inertia and will cause revs to fall faster in between shifts.
Old Aug 2, 2003 | 10:47 AM
LOwrestling2001's Avatar
Default Re: Turbo w/ light flywheel or not? (Foozball26)
9-11 lbs is fine, helps to buid boost faster
Old Aug 2, 2003 | 11:32 AM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HYREV2NR &raquo;</TD></TR><TR><TD CLASS="quote">OK here's the?. I'm going turbo in the future & would like to know if I should install a lightweight flywheel when I go to give the car a better clutchfor the extra load? I've been told to leave the stock f/w on the car by someone who has a pretty strong turbo car himself. I just want to know the reason behind this. Of course you wouldn't want to change the final drive to a lower ratio but why wouldn't you want to lighten the load on the crank? </TD></TR></TABLE>
running aasco 8.5lbs and works great..
Modified by vtec.dc2 at 5:16 PM 8/2/2003
Old Aug 2, 2003 | 11:54 AM
gzrmoto's Avatar
i got the tilton and i think it weighs like 12-14 including disc, pressure plate and i love it kinda hard to engage, some times the car just dies cause theres no weight to it. but i got over it spools faster
Old Aug 2, 2003 | 12:33 PM
93LSivic's Avatar
Default Re: Turbo w/ light flywheel or not? (gzrmoto)
The motor will spool faster and climb rpms faster.
The only tradeoff is your 60' times will suffer unless your a hardcore racer running a good drivetrain and can build boost at the line. Also you may have a problem with the car coming to an idle from high rpms and having the a/c on isnt gonna help much either.
The best all around flywheel is definetly oem ITR.
By the way, Im selling my TODA 8 lb. chromoly flywheel if your interested
Old Aug 2, 2003 | 01:05 PM
stinger's Avatar
im using the 8lbs flyhwheels with turbo im fine
Old Aug 2, 2003 | 01:13 PM
falcongsr's Avatar
What is this crap?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HYREV2NR &raquo;</TD></TR><TR><TD CLASS="quote">Eh sorry, wrong person. But I do autogragh paychecks regularly.</TD></TR></TABLE>
nevermind.
Old Aug 2, 2003 | 01:37 PM
hypa's Avatar
I've been running a CM 7.5lb flywheel in both my JRSC GSR and stock B20 (both with S80/lsd tranny) and once I figured out how to launch it, I fell in love. The car revs like a streetbike, heel-toe is cake, and the lower mass freed up some hp.
Imho, one of the better $300 mods out there.
Old Aug 2, 2003 | 02:40 PM
racinskittle's Avatar
Default Re: (hypa)
Anyone know how Indigo flywheels are? Im going to buy one with my ACT 6 puck clutch. Im turboing my D16Z6 and need a little advice. Otherwise are there any cheaper alternatives?
I've found the clutch/flywheel combo for $550.
THanks
Dan
Old Sep 7, 2003 | 09:22 AM
platinum00's Avatar
Default Re: (racinskittle)
im running a Indigo flywheel, 8.5lb, and have no issues at all. i love it. i was a little worried about it untill i saw it, the construction/quality is real nice. i dont think you will be disapointed, and for the price
platinum.
Old Sep 7, 2003 | 10:17 AM
boosted hybrid's Avatar
Default Re: (platinum00)
Watch on aluminum flywheels with high whp and torque levels. The aluminum tends to get stress fatigued very easily and permanent deformation can result. Chromoly is the best choice for a lighten flywheel.
Old Sep 7, 2003 | 11:12 AM
seen4ever's Avatar
Default Re: (boosted hybrid)
I've got a fidanza flywheel for sale, looks brand new, just had it turned because the resurfacable plates weren't worn that bad. 225 shipped, for B-series.
Old Sep 7, 2003 | 11:35 AM
boostcrazy19's Avatar
I got the ATS carbon clutch and flywheel for my 99 Si Turbo. Flywheel weighs about 3.6kg. I love it. If you can't afford this kit, get the Toda flywheel , I heard they are awesome. Don't worry bout idling problems. You will love a lighter flywheel especially w/ forced induction
SeDA(9)n
Nov 3, 2008 11:32 PM
95dc2teg
Sep 17, 2006 05:21 PM
Fuzion
20
Sep 19, 2003 03:24 AM
A92civicxJDMb16a
Sep 14, 2003 06:28 PM
Reverend
Jun 17, 2001 09:26 PM
