Pics of T3-60-1 on B18C1 block
Old Jul 30, 2003 | 04:48 PM
metal-x's Avatar
Default Pics of T3-60-1 on B18C1 block
Ok long story short I sold my Garret T3-60-1 turbo to some guy and hes claiming it wont fit his block(B18C5) and now wants his money back....
I told him you have to shave part off the block but he won't listen help me convince him!
Old Jul 30, 2003 | 05:15 PM
Blown90hatcH's Avatar
Default Re: Pics of T3-60-1 on B18C1 block (metal-x)
Its really dependent on the manifold too. I SFP race mani and I have a T4 60-1 and it clears by like 3 inches. But that turbo on a drag mani I think will not clear.
Old Jul 30, 2003 | 05:30 PM
h22 civic's Avatar
Default Re: Pics of T3-60-1 on B18C1 block (Blown90hatcH)
ill take how much whats specs and price?
Old Jul 30, 2003 | 05:33 PM
Finest's Avatar
What manifold does he run? That'll answer alot of questions...
Old Jul 30, 2003 | 05:49 PM
metal-x's Avatar
Default Re: Pics of T3-60-1 on B18C1 block (98CTRCoupe)
he's got a Maxrev manifold
Old Jul 30, 2003 | 05:55 PM
LJR-LUDE01's Avatar
well have a max-rev with a t3/t60-1 on a prelude though.. here picture maybe it helps
is a very tight fit and you can't clock the compressor outlet to face up cause it hist the manifold, so you have to clock it to face down. That's is on an h22 max-reve manifold, not sure how much different the b series manifold is.
Old Jul 30, 2003 | 06:02 PM
1.8T_EG's Avatar
Default Re: Pics of T3-60-1 on B18C1 block (LJR-LUDE01)
... what about rotating the turbo 180* and having the compressor on the drivers side... i have heard that works for some... (hopefully it will work for me)... but then he will have to redo his piping and dp...
Old Jul 30, 2003 | 06:07 PM
CheezeFrog's Avatar
Here's a few pics of mine...
MIKES's Avatar
Anything will work with modifications. Its not your responsibility to spoon feed anyone. As long as the turbo is in good condition, the rest is his problem. You did your part, let him do his own. No need to confince anyone, we are all grown here.
Old Jul 30, 2003 | 06:19 PM
metal-x's Avatar
Default Re: Pics of T3-60-1 on B18C1 block (MIKES)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MIKES &raquo;</TD></TR><TR><TD CLASS="quote">Anything will work with modifications. Its not your responsibility to spoon feed anyone. As long as the turbo is in good condition, the rest is his problem. You did your part, let him do his own. No need to confince anyone, we are all grown here.</TD></TR></TABLE>
thats a good point the turbo is brand new the problem is that he's sort off a newbie maybe I should point him here
Cheezzfrog thanks for the pics
Old Jul 30, 2003 | 06:28 PM
stackz's Avatar
at the jetties fishin'
Community Builder
Default Re: Pics of T3-60-1 on B18C1 block (CheezeFrog)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CheezeFrog &raquo;</TD></TR><TR><TD CLASS="quote">Here's a few pics of mine...
hey cheezefrog, you ever wonder why after you drop the pedal in your vid that your back rotors start to glow?? makes me wonder if your pads are dragging. did you ever fix that or anything?? i saw the vid a longggg time ago and have always wondered this.
Old Jul 30, 2003 | 07:40 PM
LJR-LUDE01's Avatar
Default Re: Pics of T3-60-1 on B18C1 block (1.8T_EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1.8T_EG &raquo;</TD></TR><TR><TD CLASS="quote">... what about rotating the turbo 180* and having the compressor on the drivers side... i have heard that works for some... (hopefully it will work for me)... but then he will have to redo his piping and dp...</TD></TR></TABLE>
it won't work, I try that and the turbo will stick out to high, if you look at the max-rev manifold flange it hold the turbo at an angle.
Old Jul 30, 2003 | 08:05 PM
1.8T_EG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LJR-LUDE01 &raquo;</TD></TR><TR><TD CLASS="quote">
it won't work, I try that and the turbo will stick out to high, if you look at the max-rev manifold flange it hold the turbo at an angle. </TD></TR></TABLE>
... sorry, i should have been more specific... this was meant for a b-series application...
Old Jul 30, 2003 | 08:26 PM
Adi Radoncic's Avatar
On Fire!
Hey,
I personally ran the T3 60-1 in my car with a b series engine and it fit for me, yes you do have to grind the **** out of the block but it will fit.
I'm assuming that the guy you sold it to has an old style max rev manifold
because about 7-8 months after the first original manifold was made they started making a manifold that fit the 60-1 in there better with the need of just the notch being trimmed off...
I would say he has two options cut the hell out of the block or mount the turbo like (Farnsrocket) a member on this forum....
Adi
Old Jul 30, 2003 | 09:16 PM
gritsak's Avatar
Default Re: Pics of T3-60-1 on B18C1 block (newgsr)
my friends got a t3/60-1 with the to4s (4" inlet, 2.5" out) housing...on a SFP race manifold and it fits with tons of room. he does have the compressor housing facing the drivers side though...i think it all just depends on the manifold...the guy should have checked out if the turbo would fit on his specific setup before he bought it.
Old Jul 30, 2003 | 10:07 PM
u2civic1's Avatar
Default Re: Pics of T3-60-1 on B18C1 block (gritsak)
it very normal to have to shave the block to make it fit
Old Jul 30, 2003 | 10:54 PM
BoosterChair's Avatar
Default Re: Pics of T3-60-1 on B18C1 block (u2civic1)
Cheezefrog, is that a custom dp or can you purchase them in that form with the cutout and all?
Old Jul 31, 2003 | 03:31 AM
BoostedsiR's Avatar
Default Re: Pics of T3-60-1 on B18C1 block (BoosterChair)
you have to notch the block with maxrev I know trut mine was notched a good amount
Old Jul 31, 2003 | 05:10 AM
Dee's Avatar
Dee
Default Re: Pics of T3-60-1 on B18C1 block (BoostedsiR)
T04S with a Kiwi mani required no cutting whatsoever.
Old Jul 31, 2003 | 05:59 AM
00ITR #543's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by metal-x &raquo;</TD></TR><TR><TD CLASS="quote">he's got a Maxrev manifold </TD></TR></TABLE>
Fits on mine..
Old Jul 31, 2003 | 07:02 AM
mike1114's Avatar
Default Re: Pics of T3-60-1 on B18C1 block (00ITR #543)
what about sandwhiching another manifold flange between manifold and head, this might make it clear the motor, but then may interfere with radiator fans. Get slim fans if its a problem.
Old Jul 31, 2003 | 09:25 AM
01ITR#700's Avatar
Default Re: Pics of T3-60-1 on B18C1 block (mike1114)
I ran a t3/60-1 on my B18C5 with a Rev Hard manifold and I had to notch the block just a little bit.
HTH
Mark
Old Jul 31, 2003 | 10:15 AM
On Fire!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00ITR #543 &raquo;</TD></TR><TR><TD CLASS="quote">
Fits on mine..
Ok guys here it is a perfect example of the new stile max rev manifold where it actually allows enough room to be able to fit a 60-1 with minimal cutting...
By the way Armando is Alive!!!
Here is what it looks like without cutting anything and trying to fit a 60-1 with an old style manifold
And here is a picture of the manifold actually fitting notice that I used 2 mr.gasket manifold gaskets and a lot of shaving and It still touches the block barely!!
As far as the radiator fans go, your alsways gona have to trim those up or get new slimmer ones...
Adi
Old Jul 31, 2003 | 02:52 PM
metal-x's Avatar
what does the new Maxrev manifold look like?
Thanks for the pics guys
Old Jul 31, 2003 | 09:17 PM
On Fire!
It looks like the one (00ITR #543) has in that picture...
Not really a big difference from the old one, I think the moved the flange over 1/4 of an inch and readjusted it 15 degrees down...
Adi
Fc_v8
Sep 21, 2010 01:01 PM
Manny1987
Sep 13, 2008 09:31 PM
PHOBIA
Dec 22, 2004 07:13 AM
Muckman
Jan 16, 2004 09:31 AM
chris@cfranklins
Jan 1, 2003 04:35 PM
