Grind the block to fit turbo?
I have a b18bLS with a t3/t4 turbo with a Spoolin performance LOG manifold. Everything fit fine with no issues. Then i bought another manifold which is the InlinePro log style (ac compatible) manifold and when i install it, a piece of the block seems to be in the way. Can i just grind down that piece and be fine? I tried clocking the turbo but it still dosent fit.
Re: Grind the block to fit turbo?
does your turbo have a 4 or 5-bolt exhaust hosuing? it is fairly common to have to "notch" the block with that style manifold. The 4-bolt exhaust housing may require alot of shaving and can get kinda sketchy
Save up the money and buy the right exh mani....dont short cut it and cut the block just b/c it rubs....
thats my personal opinion
^^ It is the right manifold. That manifold cost me little over 400$. what are you talking about. I know this problem has accured to many other turbod guys. Im trying to keep my a/c and p/s. If i wasnt i would just flip the turbo the other way and call it a day.
the manifold is technically designed for a 5-bolt turbo but you should be ok with notching the webbing. just be careful that you dont have to start grinding the engine stamp area too much.
