manifold wont fit with turbo
the drag manifold i have now will not work with my t3/t4 .57 trim. it is hitting my gsr block so which manifold will work with that turbo???
Re: manifold wont fit with turbo (1320development)
thanks for the reply. i have shaved enough to fit the turbo from the drag kit but my other turbo is a little bigger i need a manifold that goes farther away from the block. what do i do
Re: manifold wont fit with turbo (gsrcrx)
or shave your block more and make it fit...
I believe InlinePro holds the turbo further from the block, and it's angled like the Drag manifold, so you should be able to keep your downpipe
