for the big boost heads
I talked to jeff today from fulll race and with his kit running like 23 - 25 lbs of boost on a ls sleeved rods and pistons all thoose goodies, what type of injectors should I run? Jeff told me msd but I cant find them what are you guys using let me now the size and all of that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedsiR »</TD></TR><TR><TD CLASS="quote">between 400 - 500 whp</TD></TR></TABLE>
I would recommend around 780cc injectors or so, i'm running the 780cc right now and at 40psi fuel pressure, at 450whp, hitting 85% duty cycle. So right around where i'm at except u can turn up the fuel pressure a little if your hitting higher duty cycles. Paul
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by piara »</TD></TR><TR><TD CLASS="quote">RCs are good
I've used a ton of injectors in the past and never had any problems with any of them EXCEPT for RC. I've had 7 sets of rc's go bad...
</TD></TR></TABLE>I've used a ton of injectors in the past and never had any problems with any of them EXCEPT for RC. I've had 7 sets of rc's go bad...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 »</TD></TR><TR><TD CLASS="quote">
I've used a ton of injectors in the past and never had any problems with any of them EXCEPT for RC. I've had 7 sets of rc's go bad...</TD></TR></TABLE>
RC's seem to be very popular, what do you recommend?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 »</TD></TR><TR><TD CLASS="quote">good luck with greddy, msd, bosch , and precision injectors. </TD></TR></TABLE>
Thank god...... Hey are the bosch's only available in brown and black like the ones I had at your shop just amking sure?-pete
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bambooluv »</TD></TR><TR><TD CLASS="quote">
Thank god...... Hey are the bosch's only available in brown and black like the ones I had at your shop just amking sure?-pete</TD></TR></TABLE>
I have 800cc RC's and have zero problems. They are Bosch by the way.
Our bosch are blue/black
turbo*s2k
Feb 25, 2004 11:50 AM
