what size injectors ???
Old Mar 1, 2007 | 05:55 AM
rippinitup01's Avatar
Default what size injectors ???
wat size injectors should i run with my stock b16 turbo on 6-8psi??
and were could i get them for a good price
Old Mar 1, 2007 | 06:11 AM
bzyq2001's Avatar
Default Re: what size injectors ??? (rippinitup01)
RC 310
Old Mar 1, 2007 | 06:28 AM
tony413's Avatar
size= (.55)( crank HP )/ ( .85 ) ( # of injectors)
Old Mar 1, 2007 | 07:02 AM
aaronISthrowed's Avatar
Default Re: (tony413)
Psi means nothing, how much whp do you want?
Old Mar 1, 2007 | 07:04 AM
tony413's Avatar
Default Re: (aaronISthrowed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aaronISthrowed &raquo;</TD></TR><TR><TD CLASS="quote">Psi means nothing, how much whp do you want?</TD></TR></TABLE>
psi is important you wouldnt run your fuel at 30psi if your boost your car on 18psi
Old Mar 1, 2007 | 07:10 AM
97CWITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony413 &raquo;</TD></TR><TR><TD CLASS="quote">
psi is important you wouldnt run your fuel at 30psi if your boost your car on 18psi </TD></TR></TABLE>
you don't know what ur talking about
Old Mar 1, 2007 | 07:23 AM
drintegra's Avatar
DSM injectors best bang for your buck and should be fine for 300hp, if not just raise the fuel pressure.
Old Mar 1, 2007 | 03:42 PM
tony413's Avatar
Default Re: (96BLkGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96BLkGSR &raquo;</TD></TR><TR><TD CLASS="quote">
you don't know what ur talking about</TD></TR></TABLE>
would you like to inform me then since " i dont know " what im talking about seems like im the one who posted the correct way to pick the proper size injecters and if hes running 6-8psi of boost his fuel pressure needs to be around 70 to 80psi
Old Mar 1, 2007 | 05:06 PM
22psicrx's Avatar
550cc are good start
Old Mar 1, 2007 | 06:24 PM
92gisser's Avatar
I'll be runnin 440's on my gs-r, shooting for around 250whp, hopefully around 6-8psi on a b17
Old Mar 1, 2007 | 06:51 PM
NJIN BUILDR's Avatar
It depends on what engine management you using also.If you using a real management system just get some 750s and you won't ever have to worry about injectors (for almost any street build).The DSM injectors are probably the cheapest deal though.
Old Mar 1, 2007 | 07:08 PM
vtec.dc2's Avatar
psi is important just not directly related to how much hp you're gonna make per psi. different size turbos will make different hp at same psi, but it also depends on exhaust/charge piping size/engine/rpm - it all effects on how much hp you're going to make at certain psi. we all have 4 cylinders in here, some rev higher than others but in general we would use same size injector for X amoung of hp. to thread starter, post how much hp you want to make and you'll get a better answer
Old Mar 1, 2007 | 07:47 PM
vtec8804's Avatar
* B A N N E D *
im in the same boat.. if i get 440s and i want to run a reliable setup at say 250 260whp thats pretty much all 440s can handle correct?
Old Mar 1, 2007 | 07:57 PM
b18sihatch's Avatar
dsm injectors
Old Mar 1, 2007 | 08:00 PM
vtec8804's Avatar
* B A N N E D *
is there wiring n sodering when u go to dsm n thats not better then gettin some 440s is it thats just a cheaper way out
Old Mar 1, 2007 | 08:33 PM
tony413's Avatar
Default Re: (vtec.dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec.dc2 &raquo;</TD></TR><TR><TD CLASS="quote">
psi is important just not directly related to how much hp you're gonna make per psi. different size turbos will make different hp at same psi, but it also depends on exhaust/charge piping size/engine/rpm - it all effects on how much hp you're going to make at certain psi. we all have 4 cylinders in here, some rev higher than others but in general we would use same size injector for X amoung of hp. to thread starter, post how much hp you want to make and you'll get a better answer</TD></TR></TABLE>
did you read my very first post with the equation thats the best way to decide plug in the numbers an get an exact answer
Old Mar 2, 2007 | 06:46 AM
Default Re: (vtec8804)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec8804 &raquo;</TD></TR><TR><TD CLASS="quote">im in the same boat.. if i get 440s and i want to run a reliable setup at say 250 260whp thats pretty much all 440s can handle correct?</TD></TR></TABLE>
If i were you i would get 550s, so theres always a little room to grow.
f1 vtec
Jan 29, 2006 12:58 PM
mrkal
Jan 22, 2006 06:03 PM
xtremecoupe
Nov 21, 2005 02:05 PM
Excelerate
Jul 7, 2005 12:15 PM
BoostedsiR
Jul 31, 2003 09:19 PM
