can't boost past 3psi all of a sudden
For the past couple months I have been running 8 psi just fine. no problems. Then today for some reason it won't boost past 3 psi. Anyone know what could possibly cause this? My SBC-ID still works apparently, as it is reading the boost "properly" but I am unable to run at 8. I haven't changed anything, so that shouldn't be the problem. Could it be that it is hot as **** here right now? It's 102 (texas) I'm not sure how this would affect it though. Please any help you can offer would be great, I'm freaking out!
Thanks for the reply. After driving it around the block again, listening for anythign weird. It doesn't even sound like it is spooling right. Something just sounds sorta funny, almost like a slightly rapsy sound. any ideas?
That wasn't the problem. Both gaskets are fine. I noticed that my intake tubing with the filter on the end is disconnected slightly. Could this be the problem? No pressure or vacuum or something? I don't think it would be, but at this point I'll try anything. It's too dark right now, so if anyone has suggestions, please give them!
what about the waste gate int holding boost because with a good enough vacum leak you wouldnt boost at all like, check all vacumm sources first then it could be a spring in the waste gate I ve seen it happen before
I figured it out!!!! one of the little silicone seals between the chargepipe and the intercooler had come off. I eyeballed it last night but couldn't tell because it was too dark. Got it fixed now though!!! thanks everyone : )
fiaz79
Mar 11, 2003 01:56 PM
