TOO MUCH VAC (NO BOOST)
Old Jun 1, 2005 | 02:48 PM
RFd15bhatch's Avatar
Default TOO MUCH VAC (NO BOOST)
my guage is reading 30. I put the turbo kit on it ran good for a few days then it lost all boost. I think my intkae mani gasket blew. Would that cause my car not to boost.
Old Jun 1, 2005 | 02:56 PM
Trance minister's Avatar
Default Re: TOO MUCH VAC (RFd15bhatch)
Wastegate stuck open, boost leak at either a charge pipe coupler or elsewhere, or even possibly a blown IM gasket like you stated.
Old Jun 1, 2005 | 03:14 PM
Default Re: TOO MUCH VAC (Trance minister)
wastegateis not even opening, it is not holding enough boost to open the wastegate. all the charge pipes are good.
Old Jun 1, 2005 | 03:29 PM
mamaboy's Avatar
wastegate not opening would result in overboost. double check all your connections in your plumbing. if you had a blown intake manifold gasket your going to run lean, dependant on how big the failure is. don't boost until you get that fixed.
Old Jun 1, 2005 | 03:35 PM
Default Re: TOO MUCH VAC (mamaboy)
It does not boost at all. The turbo is not boosting enough to open the wastegate. i have gone over all the connections i cant think of anything else to check.
turbo-crx
Jan 24, 2009 09:06 AM
93turbo16
Sep 14, 2005 11:15 AM
ldanphanl
Aug 23, 2005 05:31 PM
crispydee
Oct 17, 2004 10:47 AM
teamrocket si
Feb 10, 2002 02:27 PM
