Car bogs under nitrous. Need help quick.
Old Jul 27, 2003 | 09:01 PM
blackc's Avatar
Default Car bogs under nitrous. Need help quick.
A friend of my is having problems with his nitrous kit every time he sprays his car bogs! bad!! it like looses power!! if anyone has any ideas let me know everything is welcome! thanks!
p.s. I think that it might be where the nitrous go into the intake it is about 4" away from the throttle body. could that be the problem?
It is a NX wet kit with a 50 shot NOS fogger on a DOHC ZC
Thanks everyboy I really need the help
Old Jul 27, 2003 | 09:44 PM
blackc's Avatar
ttt
Old Jul 27, 2003 | 09:53 PM
Bspec18's Avatar
Default Re: (dldom)
what kind of plugs are you using ? did you retard the timing a little ? is he spraying at WOT ?
Old Jul 27, 2003 | 10:16 PM
blackc's Avatar
Default Re: (Bspec18)
Stock plugs. stock timing and WOT swith for activation. What are you thinkin man.
Old Jul 27, 2003 | 11:07 PM
blackc's Avatar
Default Re: (dldom)
bizzump
Old Jul 28, 2003 | 12:54 AM
ichibanjap's Avatar
Default Re: Car bogs under nitrous. Need help quick. (dldom)
What year is the car and has the fuel pump ever been replaced or upgraded?
Old Jul 28, 2003 | 10:39 AM
blackc's Avatar
Default Re: Car bogs under nitrous. Need help quick. (ichibanjap)
the car is a 91 crx and the fuel pump has not ben replaced.
Old Jul 28, 2003 | 02:51 PM
blackc's Avatar
up up and away! anyone?
Old Jul 28, 2003 | 02:53 PM
slowsi00's Avatar
make sure the bottle is on if not the car will just have fuel spraying into the throttle body causing the car to be slower. my buddy did this before
Old Jul 28, 2003 | 03:25 PM
blackc's Avatar
Nope checked that already. Anybody else have ever have a similiar problem?
Old Jul 28, 2003 | 03:51 PM
slowsi00's Avatar
Default Re: (dldom)
u check the nitrous noid?
Old Jul 28, 2003 | 04:14 PM
Full-Race Henry's Avatar
Default Re: (dldom)
I usually dont deal with nitrous but my friend had the same exact problem. It could be a few different things.
Make sure that your nitrous is working, take off the line and try spraying it, if it sprays, then check both of your jets and make sure they are the right ones.
He was bogging down also because his nitrous wasnt spraying, we pulled off the line and tryed spraying and nothing was comin out. there was a bad kink in the line so we had to get a new one. after we got the new line, he tried spraying again, it bogged down again, which really started to **** us off, well he didnt have the right jets so when it was activated, it was still running too rich, after he got the right jets, it worked fine. Then he blew his motor.
Old Jul 28, 2003 | 04:24 PM
BoostedSi's Avatar
Default Re: (EF8_Fan)
yea, make sure that the jets are the right ones. The fuel jet might be too big.
Old Jul 28, 2003 | 08:02 PM
blackc's Avatar
Alright Im takin it to a nitrous guy tommorrow to see what he thinks. But from what Im getting my mixture is too rich. I guess we'll see. Anybody else have any suggestions................
Old Jul 28, 2003 | 08:26 PM
1dumbscreenname's Avatar
Default Re: (dldom)
this is stupid, make sure that the bottle is filled/full. one time i had my btl heater on and the heater made it read 950psi, so i thought things were fine but after one gear the bottle was empty, so it bogged and backfired. make sure there is nitrous in the bottle.
Old Jul 28, 2003 | 08:33 PM
RedHB's Avatar
Default Re: (dldom)
Also, be sure to check that the nitrous and fuel jets are not reversed.
Old Jul 28, 2003 | 08:35 PM
laughinxxx's Avatar
New User
Default Re: (1dumbassscreenname)
1. low bottle pressure
2. no nitrous in bottle
3. nitrous noid isn't opening
4. nitrous seal is deformed
5. nitrous filter is clogged
6. nitrous line is clogged
7. nozzle is clogged
8. leak in nitrous line
9. wrong sized jets
10. jets are switched
Your fuel pressure could also be excessive, but I seriously doubt that is the case. Check the above 10 possible causes. I'm assuming that you are using the noids that came with the NX kit so your jets should be correct for the noids you are using.
si0385.
Jan 29, 2007 05:34 PM
Wide Open Throttle
Nov 2, 2003 05:07 PM
tmekjian
Jun 11, 2003 11:35 AM
crxtreme27
Dec 27, 2002 07:27 AM
Phat_GSR
Aug 23, 2002 10:19 AM
