nitrous detnation problem
Old Jan 28, 2007 | 07:54 AM
si0385.'s Avatar
Default nitrous detnation problem
i just installed a 75 shot wet kit (nitrous express) the fuel jet is a 24 and the nitrous jet is a 41... its an ls/vtec with jdm itr pistons and a stock 98 jdm itr head... im using one step colder plugs (bkr7e ngk) and have always ran 93 oct but i am havin detnation problems... and the ignition timing is all the way retarted
do you think it would be best to up the fuel jet, adjust the fuel presure regulator to flow more fuel (idk if that would help because the jet will only alow so much fuel) run another step colder plug
it runs smoth untill vtec enguages than it starts to detnate, i pulled a few plugs and they looked like they had salt and pepper on them and they were brand new before i ran the nitrous
any help is much appreciated
-chris
Old Jan 28, 2007 | 09:23 AM
f1 vtec's Avatar
Default Re: nitrous detnation problem (si0385.)
I think for 75 shot nos u need to retard timing by 4 degrees, make sure that is the case. I think you will be fine with those plugs im sure i used Bkr7e-11 when i nossed.
Im not sure about the jet numbers you are using. But with a wet shot i dont think you should be worrying about fuel, its probably your timming that is out.
What are you using to retard ignition?
Old Jan 28, 2007 | 09:48 AM
nonvtecallmotor's Avatar
I never liked those plugs in a nitrous car. I use zfr7e-11 gap at 25-30.
Old Jan 28, 2007 | 09:58 AM
SOHC_MShue's Avatar
do you have a wideband?
Old Jan 28, 2007 | 10:25 AM
si0385.'s Avatar
no i have no wide band and all i did to retard the timing was turn the distributor
nonvtecallmotor who makes those plus that you use is that an ngk number?
Old Jan 28, 2007 | 10:31 AM
Default Re: (si0385.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si0385. &raquo;</TD></TR><TR><TD CLASS="quote">no i have no wide band and all i did to retard the timing was turn the distributor
nonvtecallmotor who makes those plus that you use is that an ngk number?</TD></TR></TABLE>Yes NGK They are a stock plug but 1-2 steps colder. I have sprayed as much as a 200 shot on these plugs.
I would check your timing with a timing light. set it about 12-13*. You might of retarded your timing to much.
Old Jan 28, 2007 | 11:29 AM
SOHC_MShue's Avatar
do you even have anything to tune with. Sounds like this is a dissaster waiting to happen
Old Jan 28, 2007 | 09:50 PM
b00stME's Avatar
Default Re: (SOHC_MShue)
i believe u dont need a wideband to tune a nitrous system, just checking the plugs and adjusting jets.
Old Jan 28, 2007 | 09:53 PM
b00stME's Avatar
Default Re: (nonvtecallmotor)
wouldnt it be best leaving your distributor alone and retard timing with a msd box? or running 2 map threw ecu/engine management with nitrous and without
Modified by b00stME at 1:52 PM 1/29/2007
Old Jan 29, 2007 | 06:14 AM
SOHC_MShue's Avatar
Default Re: (b00stME)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b00stME &raquo;</TD></TR><TR><TD CLASS="quote">i believe u dont need a wideband to tune a nitrous system, just checking the plugs and adjusting jets.</TD></TR></TABLE>
i believe you dont know what you are talking about
For one he running a lsvtec with jdm itr pistons...that setup alone really could use a good tune. Running a stock ecu will not get things done right.
Old Jan 29, 2007 | 06:59 AM
b00stME's Avatar
makes sense, hopefully he tuned his motor with a wideband
Old Jan 29, 2007 | 03:46 PM
sc4dr's Avatar
Hopefully he turned the distributor the right way
Old Jan 29, 2007 | 05:34 PM
SOHC_MShue's Avatar
Default Re: (sc4dr)
silverlude80
Nov 8, 2007 10:13 AM
95greenlude
May 2, 2007 02:02 PM
DA9kid
Jan 1, 2007 04:50 PM
PowerSpeed Motorsports
Jun 12, 2006 06:05 AM
tmekjian
Jun 11, 2003 11:35 AM
