77mm D16 Headgasket Choice
Old Jul 26, 2003 | 09:43 AM
M.A.R.C.'s Avatar
Default 77mm D16 Headgasket Choice
Well. I dropped off my block at VaporTrail's shop yesterday and now i have to get a head, headgasket and headstuds for the assembly. It's a 77mm D16Z6 block and i been looking into the headgasket choice. i checked race engineering... they only had like 75 (stock) and like 76 and 78mm Cometic headgaskets. i was also recommened to get a SCE copper headgasket. What is everyone's opinion on headgaskets? Once again the block is a GE sleeved D16, 77mm bore, 9:1 compression. anyone know a good 77mm headgasket?
Old Jul 26, 2003 | 05:49 PM
M.A.R.C.'s Avatar
Default Re: 77mm D16 Headgasket Choice (CivicRyda2k)
ttt
Old Jul 26, 2003 | 06:27 PM
boosted hybrid's Avatar
I prefer OEM gaskets. The GE overbored OEM would be the best choice for sealing.
Old Jul 26, 2003 | 07:19 PM
D-Man's Avatar
Is the block O-Ringed?
Old Jul 26, 2003 | 11:54 PM
M.A.R.C.'s Avatar
Default Re: 77mm D16 Headgasket Choice (boosted hybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted hybrid &raquo;</TD></TR><TR><TD CLASS="quote">I prefer OEM gaskets. The GE overbored OEM would be the best choice for sealing.</TD></TR></TABLE>
i thought about that too.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-Man &raquo;</TD></TR><TR><TD CLASS="quote">Is the block O-Ringed?</TD></TR></TABLE>
no it's not
Old Jul 27, 2003 | 05:15 AM
D-Man's Avatar
Then I wouldnt use the SCE Copper Headgasket.I think your best bet is probably what boosted hybrid said.
Old Jul 27, 2003 | 06:25 AM
ladysman's Avatar
Default Re: 77mm D16 Headgasket Choice (D-Man)
I am using a cometic on my 78mm D series built block.
Old Jul 27, 2003 | 06:47 AM
M.A.R.C.'s Avatar
Default Re: 77mm D16 Headgasket Choice (ladysman)
yah i've been getting recommended to use the OEM/GE one
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ladysman &raquo;</TD></TR><TR><TD CLASS="quote">I am using a cometic on my 78mm D series built block.</TD></TR></TABLE>
yah but mine's 77mm
Old Jul 27, 2003 | 07:41 AM
ladysman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicRyda2k &raquo;</TD></TR><TR><TD CLASS="quote">yah i've been getting recommended to use the OEM/GE one
yah but mine's 77mm
77 or 78, that is really irrelevant.
GE recommends a OEM IF the machining is done by them. Mine was not machined by them and the person who built mine only uses cometic's.
Who did the machining?
Old Jul 27, 2003 | 08:16 PM
M.A.R.C.'s Avatar
Who did the machining?</TD></TR></TABLE>
ah ok... i thought the hg bore had to match the block bore. GE did the machining. Secret Services (VaportTrail) is doing the assembly so ill check with him on what headgasket he uses
Old Jul 28, 2003 | 04:00 AM
ladysman's Avatar
ah ok... i thought the hg bore had to match the block bore. GE did the machining. Secret Services (VaportTrail) is doing the assembly so ill check with him on what headgasket he uses</TD></TR></TABLE>
Sorry, maybe I wasn't clear. Of course the HG bore must match the block bore. My point was having a 77 or 78 is really irrelavant as to what gasket you get.
Where the machining was done is what you need to go by (GE recommendation). Just get the OEM one matched to your bore size.
Old Jul 28, 2003 | 06:13 AM
VTC_CiViC's Avatar
GE modified OEM gastket.. it's what I was going to use
integraboosted
Oct 3, 2007 10:12 AM
Redvti
Apr 10, 2006 09:45 PM
bigapple427
Jul 12, 2005 10:15 AM
ATS*Mark
Apr 28, 2004 08:03 AM
turbo89civicb18hatch
Apr 5, 2004 09:10 AM
