on a EGT gauge...
Old Aug 4, 2001 | 01:22 AM
Crxlsturbo's Avatar
Default on a EGT gauge...
at what degress does the engine start to lean out? I have a Greddy EGT gauge and want to know where should I set the warning light at. Please help.. Thank you every1.. Peace out
Marc
Old Aug 4, 2001 | 01:27 AM
redline's Avatar
Default Re: on a EGT gauge... (Crxlsturbo)
840c
Old Aug 4, 2001 | 01:47 PM
turbogsr's Avatar
Default Re: on a EGT gauge... (redline)
Don't automatically say 840C b/c we don't know where he put his probe. Remember, its different if he has his probe before the turbo than if he has his probe after the turbo. For example, I have my probe on the downpipe which is after the turbo, but a lot of people put the probe on the manifold before the turbo. The temps are obviously going to be a lot hotter on the manifold than on the downpipe. Where do you have your probe?
Old Aug 4, 2001 | 10:59 PM
Crxlsturbo's Avatar
I am going to put the probe on the #1 cylinder tapped into the turbo manifold. So what should my EGT read when it start to detnoate? Thank you... Peace out
Old Aug 5, 2001 | 02:15 AM
B18C-EJ1
Guest
Posts: n/a
Your probe should be 4" after the turbo. This will give you a good average reading of all cylinders, not just 1.
Old Aug 5, 2001 | 03:37 AM
Crxlsturbo's Avatar
Default Re: on a EGT gauge... (B18C-EJ1)
but from what I am told is that you are suppose to put it on the leanest cylinder which is #1. It gives you a more accurate reading. The #1 cylinder is the leanest because it is the furtherest from the fuel line that reaches the fuel rail...
Old Aug 5, 2001 | 10:11 AM
falcongsr's Avatar
What is this crap?
However, the #3 cylinder runs hottest because it gets water warmed by #1 and #2 and it doesnt have water around 7/8 of it like #4.
O O O O <- water flow
4 3 2 1
Old Aug 5, 2001 | 01:05 PM
98hx99b18c's Avatar
Default Re: on a EGT gauge... (falconGSR)
Yes put it on the number 3 cylinder,that is the cylinder that will run the leanest because of the head cooling, check out the pic at the bottom of the link for an idea of how far to place it back...http://www.maxrev.com/catalog/engine/header.html
victoriasamantha
Mid-Atlantic (Sales)
May 25, 2009 06:17 AM
ThePro
May 10, 2005 06:42 AM
Egg-weezy
Mar 31, 2004 08:04 PM
slowsi00
Mar 11, 2003 02:17 PM
cokex
Oct 19, 2002 06:42 PM
