93 si hatchback engine swap?
Old Jul 14, 2003 | 01:01 PM
sikcrx80's Avatar
Default 93 si hatchback engine swap?
now is it hard to do a swap in one of these as they already have vtec do i have to add any wires for it?
we will be putting a SIR b16a in it..
what shafts do i use and what linkages do i use?
Old Jul 14, 2003 | 02:00 PM
BrynnTheSlut's Avatar
For a B16 it should be a direct swap. Just swap over the harness from the Si onto the B16 and you should be set. The B series axles will work and i forget what to use for the linkage. If im forgetting anything fill me in.
Old Jul 14, 2003 | 02:03 PM
salbaje's Avatar
Default Re: 93 si hatchback engine swap? (sikcrx80)
use 94-00 gsr linkages, b series axles. you need to wire in knock sensor.
Old Jul 14, 2003 | 07:10 PM
sikcrx80's Avatar
so wire up knock sensor and get a set of SIR drive shafts. is there anyother drive shafts that are prob cheeper then them.
now i will still have to do a hasport mount kit right?
ILoveJDM89
Sep 21, 2008 06:00 PM
hondatuner020
12
Dec 27, 2007 06:32 AM
BeerBaron105
Sep 6, 2004 02:39 PM
ALLMOTADELSOL
Jun 6, 2003 12:28 AM
projecthybrid04
Aug 23, 2002 02:22 PM
