turbo on b18b1...setting timing?
Old Jul 10, 2003 | 10:34 PM
B_1_8_hatch's Avatar
Default turbo on b18b1...setting timing?
how far back should the timing be running a turbo on an ls motor. i've heard that some people leave their timing stock if they are boosting under 10psi. i've also heard that for every pound of boost you run...set your timing back .5 a degree.
what are you guys setting it at?
Old Jul 11, 2003 | 02:55 AM
Sohc Driver's Avatar
Default Re: turbo on b18b1...setting timing? (93hb)
i would also like to know this...bump
Old Jul 11, 2003 | 05:06 AM
highmilehatch's Avatar
This depends what your engine management setup is. Leave it at 16 degrees if your running management and let the computer take timing out under boost. Factory computer either requires you to pull back base timing at the distributor or run some kind of boost retard unit like the msd.
Old Jul 11, 2003 | 03:11 PM
Default Re: turbo on b18b1...setting timing? (highmilehatch)
Lets say..i plan to run 5-6lbs of boost with a 12:1 FMU/Missing Link...how much should i retard my timing?
Khoi
Old Jul 15, 2003 | 05:33 PM
Default Re: turbo on b18b1...setting timing? (Sohc Driver)
bump
Old Jul 15, 2003 | 05:34 PM
Mr. Softee's Avatar
you cant take out timing per lb with the distributor, best bet is to go hondata or similar and do it the right way. static timing adjustment sucks as your only timing adjusting tool.
Old Jul 15, 2003 | 06:53 PM
Default Re: turbo on b18b1...setting timing? (94goldjungsr)
yeah, but for some people, that is all they can afford. they have to do whatever gets them buy until they can get the good ****.
i have mine set at 14 degrees running 8psi and i don't have any problems.
Old Jul 15, 2003 | 06:55 PM
spike's Avatar
chip your ecu for ghettodyne and burn a prom to retard per psi.. all this can be done for under 100 bucks.. that's going to be my solution, however you have to run an obd1 or obd0 ecu .. as far as i know that's all ghettodyne supports right now.
Old Jul 15, 2003 | 09:35 PM
sorry...setting my to 13 degrees...not 14
Old Jul 15, 2003 | 10:23 PM
rygan21's Avatar
so which side is better to error on? (too little fuel or too much?)
Old Jul 15, 2003 | 11:41 PM
Mr. Softee's Avatar
Default Re: turbo on b18b1...setting timing? (rygan21)
i think ghettodyne only works for OBD 0
Old Jul 16, 2003 | 03:04 AM
spike's Avatar
oh for real.. my bad.. guess i think was thinking of ecucontrol.. either way for obd0 you can't beat free software ..
Old Jul 16, 2003 | 07:24 AM
Remember this though. There is no universal amount of timing per psi to take out. You have to take into consideration the flow aspects of the turbocharger being used. One turbo might flow way more air at 8 psi than a smaller unit. With that being said, more air=more potential for power. More power means more cylinder pressure, meaning you might need to take more timing out with a turbo pushing the same amount of air at 8 psi as a smaller one at 15 psi. Since every combination is different, one setup might require more or less timing at the same psi. The best way is to just bite the bullet and shell out the money for quality engine management system and good tuning.
Old Jul 16, 2003 | 09:08 AM
up
Modified by 93hb at 12:59 AM 7/17/2003
Old Jul 16, 2003 | 09:17 AM
silverEH2's Avatar
i put mine at 14 degrees
Old Jul 16, 2003 | 09:25 AM
90teg's Avatar
what's ghettodyne?
Old Jul 24, 2003 | 02:55 PM
Default Re: turbo on b18b1...setting timing? (90teg)
anyone else have some info for timing on a turbocharged b18b1?
Old Jul 27, 2003 | 12:22 PM
Default Re: turbo on b18b1...setting timing? (silverEH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silverEH2 &raquo;</TD></TR><TR><TD CLASS="quote">i put mine at 14 degrees</TD></TR></TABLE>
Cool..so how is the car running? still smooth as pie? Also what is your setup?
Khoi
Old Jul 27, 2003 | 04:05 PM
glagola1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93hb &raquo;</TD></TR><TR><TD CLASS="quote">anyone else have some info for timing on a turbocharged b18b1?</TD></TR></TABLE>
Drive it and listen for detonation. If you hear it, stop, and retard your distributor a little bit. Test and listen again. When it goes away, you're done. If you just listen to the sound of your motor you can gain so much info on how it's running.
Old Jul 28, 2003 | 01:33 PM
silverEH2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sohc Driver &raquo;</TD></TR><TR><TD CLASS="quote">
Khoi</TD></TR></TABLE>
yeah it was running smooth as pie until it got stolen and totaled, until that day it was running hard as ****
xcountrirunr
Dec 1, 2004 08:57 AM
bmm89
Nov 21, 2004 08:17 PM
CRXLST
Oct 27, 2004 09:45 PM
wzcb08
May 19, 2003 07:47 PM
wrXtian
Mar 25, 2003 03:55 PM
