tial wastegate springs????? which is best???
Old Jul 8, 2003 | 09:43 PM
CIVILGSR's Avatar
Default Wastegate Help PLEASE need fast help
Now I need to get a wastegate and I heard it was better to buy the smallest spring and just use the boostcontroller to adjust the boost. Does that make sense or does it matter what size spring I initially order with my wastegate????
Modified by CIVILGSR at 11:09 AM 7/9/2003
Old Jul 8, 2003 | 09:51 PM
Pelican's Avatar
Default Re: tial wastegate springs????? which is best??? (CIVILGSR)
just be realistic about what kind of boost you're gonna run. And think about it and how the spring works.
If you get a 9 psi spring, and you have a manual boost controller, it can't be set any lower than 9 psi. because if there is only say 5 psi in the line, the spring won't open all the way.
Old Jul 8, 2003 | 10:00 PM
CIVILGSR's Avatar
Default Re: tial wastegate springs????? which is best??? (Pelican)
I plan on running about 12 lbs on the street and more on the track so I was wondering that if I had a electronic boost controller to adjust the boost does it matter what size spring I get???????
Old Jul 9, 2003 | 07:25 AM
CIVILGSR's Avatar
well I need to order the boost controller today, is there anybody that can help clear up my question???
Old Jul 9, 2003 | 07:35 AM
SIXTYdashONE's Avatar
HT's Biggest Loser
like pelican said earlier, factor in what amount of boost your going to run. If our going to run 20psi and shoot for high hp, dont get a small 5-7 psi spring, it will creep. If your going to run 12psi, then a 7psi spring should be fine, just kep in mind that 1. you cant go any lower then that 2. If you plan on running higher bost inthe future, you ma have to upgrade springs to be safe.
Old Jul 9, 2003 | 07:41 AM
93LSivic's Avatar
Default Re: tial wastegate springs????? which is best??? (SIXTYdashONE)
This should help you out a lot. Put on your notepad.....I did, thanks bottoz
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bottoz &raquo;</TD></TR><TR><TD CLASS="quote">Here are the spring pressures and colors:
35mm TiAL / spring discription
.3 bar / 4.35psi / <FONT COLOR="yellow"> small yellow</FONT>
.45 bar / 6.53psi / <FONT COLOR="red">small red</FONT>
.65 bar / 9.43psi / <FONT COLOR="green">small green</FONT>
.8 bar / 11.6psi / <FONT COLOR="blue">small blue</FONT>
35mm TiAL HP (35mm bottom + 40mm top)
.95 bar / 13.78 / <FONT COLOR="yellow">big yellow</FONT>
1.1bar / 15.95psi / <FONT COLOR="red">big red</FONT>
1.35bar / 19.58psi / <FONT COLOR="green">big green</FONT>
1.5bar /21.75psi / <FONT COLOR="blue">big blue</FONT>
40mm TiAL
.25 bar / 3.63psi / <FONT COLOR="yellow">small yellow</FONT>
.4 bar / 5.80psi / <FONT COLOR="red">small red</FONT>
.5 bar / 7.25psi / <FONT COLOR="green">small green</FONT>
.6 bar / 8.70psi <FONT COLOR="blue">small blue</FONT>
.7 bar / 10.15psi / <FONT COLOR="yellow">big yellow</FONT>
.8 bar / 11.60psi / <FONT COLOR="red">big red</FONT>
.9 bar / 13.05psi / <FONT COLOR="green">big green</FONT>
1.0 bar /14.50psi / <FONT COLOR="blue">big blue</FONT>
40mm TiAL HP (combine big and small springs to get desired output)
Bottoz</TD></TR></TABLE>
Old Jul 9, 2003 | 07:57 AM
Bottoz's Avatar
Default Re: tial wastegate springs????? which is best??? (93LSivic)
Thanks!
Bottoz
Old Jul 9, 2003 | 08:05 AM
01ITR#700's Avatar
Default Re: tial wastegate springs????? which is best??? (Bottoz)
Per Tial, the spring you run should be the minimum amount of boost you plan on running. So if you want to run 12psi daily, and more at the track, then get the spring closest to 12psi. Then get a boost controller to run anything above that.
HTH
M
Old Jul 9, 2003 | 08:25 AM
ineedhelp's Avatar
Default Re: tial wastegate springs????? which is best??? (01ITR#700)
where can you purchase these springs at?
Old Jul 9, 2003 | 08:32 AM
int3gra's Avatar
how much do those springs run?
Old Jul 9, 2003 | 08:53 AM
HT's Biggest Loser
Default Re: tial wastegate springs????? which is best??? (int3gra)
Not to change topic, but i have a TIAL small blue spring or sale $30, if anyone needs it.
powerdbygarrett
Jul 3, 2008 01:50 PM
Harassing Herbs
Mar 1, 2004 08:31 PM
shingles
Jan 24, 2003 01:58 AM
wonny
May 30, 2002 03:18 PM
