Wastegate dismantling
Old May 30, 2002 | 10:05 AM
wonny's Avatar
Default Wastegate dismantling
I want to replace the 9 lb spring in my wastegate with a 5 lb one.
How hard is it to take apart the wastegate? Is it possible to run without a spring and just controll the boost with a boost controller?
Thanks,
Dave
Old May 30, 2002 | 10:12 AM
jbsadler's Avatar
New User
Default Re: Wastegate dismantling (wonny)
What type of wastegate?
Old May 30, 2002 | 10:53 AM
inspyral's Avatar
Default Re: Wastegate dismantling (jbsadler)
without a spring, you probably won't even see boost
Old May 30, 2002 | 11:14 AM
wonny's Avatar
Default Re: Wastegate dismantling (inspyral)
Turbonetics deltagate.
My thinking is running without a spring but controlling the boost with a boost controller. Since the boost controller can only regulate boost above the spring rate, having a zero rate would allow you to control boost from 0 LBS to whatever you want, right?
I'm kicking in the dark here, let me know if this makes sense.
Is it hard to dismantle?
Old May 30, 2002 | 11:45 AM
ceemarun's Avatar
i'd definately want to know this too. i never thought of having no spring at all. if any of you can describe how to change the spring on a tial, too, that'd be great. im in the same boat as wonny
Old May 30, 2002 | 11:55 AM
boosted3g's Avatar
Default Re: Wastegate dismantling (ceemarun)
If you run with no spring you are going to tear the diaphram in the wastegate since there will be nothing limiting its travel. Also you wont see any boost at all due to the fact that you wont have any way of closing the wastegate. That is what the spring is there for.
Old May 30, 2002 | 11:57 AM
BoOsTeD_eK's Avatar
Default Re: Wastegate dismantling (boosted3g)
I always though boost controllers only allowed you to adjust the boost within the range of the wastegate....are you telling me that if I have a 9lb spring..on my wastegate....that i could boost to 15psi...using a boost contoller? That doesnt make sense.
Old May 30, 2002 | 12:03 PM
ceemarun's Avatar
Default Re: Wastegate dismantling (BoOsTeD_eK)
boost controllers can only INCREASE boost above what the spring is rated at, right?
Old May 30, 2002 | 03:18 PM
inspyral's Avatar
yup
powerdbygarrett
Jul 3, 2008 01:50 PM
Harassing Herbs
Mar 1, 2004 08:31 PM
oMek
Feb 29, 2004 09:09 PM
Cyber ITR
Jan 19, 2004 03:38 AM
shingles
Jan 24, 2003 01:58 AM
