oil gauge install help
That is really the only place unless you hook a line to the one behind your head near the distributer. The stock oil pressure sensor is the best place to put it. Why do you want to put it elsewhere?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whiteinteg95 »</TD></TR><TR><TD CLASS="quote">is there anywhere else i can tap my oil pressure gauge on my b18c besides unhooking my oil pressure sensor and putting it there?</TD></TR></TABLE>
He wants to know where he can put it other then that spot.
Use a sandwich plate to give you a pair of oil feed ports. You can use them for whatever you want. Turbo oil feed, oil cooler, gauge lines, etc.
M20x1.5mm thread size on the oil filter bolt.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC »</TD></TR><TR><TD CLASS="quote">Use a sandwich plate to give you a pair of oil feed ports. You can use them for whatever you want. Turbo oil feed, oil cooler, gauge lines, etc.
M20x1.5mm thread size on the oil filter bolt.</TD></TR></TABLE>
dont buy the GReddy plate as its fittings will only fit GReddy taps/lines/gauges(not cheap!!!)....like i found out after i bought the ******* thing!
does anybody have a pic or can get a pic of the port i can use for the oil pressure gauge behind the head next to distributor. I think i know which one but not sure. Does it require an allen wrench to be taken off?
Just buy one of those Ac Autotechnic sandwitch plates that screws in between your filter and your block. I have one on mine and have no problems with it at all.
RACEPAK
Jun 4, 2006 02:34 PM
dan_w_82
Mar 7, 2005 12:38 PM
turbotime
Nov 29, 2003 04:58 PM
