which regulator and wastegate do u recomend?
Old Jul 25, 2001 | 12:05 PM
PROFILES2000's Avatar
Default which regulator and wastegate do u recomend?
i am pickin up my turbo,manifold,3"downpipe IC ic piping and return and sending lines this weekend......i need to but a fuel regulator and a wastegate what do you recomend. (at this moment i am running a tock b18c1 block with a b16a head for compression of 9.7 or 9.8-1)
what do u recomend and how much boost is to much for this stock setup?
Old Jul 25, 2001 | 12:11 PM
newspeedR's Avatar
Default Re: which regulator and wastegate do u recomend? (Y2kGsR)
suckkaa.... so thats the big secret... youll see... haha... your compression is much higher than 9.7, 9.8, you are in the 10's... as far as boost, if you dont want to hear boom... dont do more than 6 or 7 psi
Old Jul 25, 2001 | 12:42 PM
b18bturbo's Avatar
Default Re: which regulator and wastegate do u recomend? (newspeedR)
tial wastegate and aermotive fpr
Old Jul 25, 2001 | 12:55 PM
can u pass the blunt or what ever yer smoking on over here? since when does a b16 head on a b18c1 block produde ahigher compression ratio than stock?
yes a stock gsr engine in 10-1 but mine is not the stock like setup
Old Jul 25, 2001 | 01:45 PM
The Mick's Avatar
Hey Y2kGsR,
Remember me? I have the "other" '00 DVP GS-R. Congrats on coming over to the darkside.
A TiAL wastegate would be a good choice, IMO.
Old Jul 25, 2001 | 01:46 PM
paulzy's Avatar
I kinda remember that the b16 head on a b18c1 block will give you higher compression numbers. Wasn't it due to the fact that the b16 head is lower(kinda like milling a head)? I don't know, someone correct me if this is wrong...
But I suggest a tial wastegate...
Old Jul 25, 2001 | 02:51 PM
redline's Avatar
Default Re: which regulator and wastegate do u recomend? (Slow_ass_4dr)
Do you want a boost depandent FPR then vortech if the other my AEM works jsut fine.
Tial wastegate
B16a head a on GSR block lower compression.
Type r piston in a GSR motor raise compression.
It is all about head design.
k
Old Jul 25, 2001 | 03:02 PM
Marc's Avatar
Default Re: which regulator and wastegate do u recomend? (redline)
I have an HKS external wastegate if you're interested. $225 shipped to your door.
E-mail me at d16y8@hotmail.com
Old Jul 25, 2001 | 04:46 PM
pellie's Avatar
New User
Default Re: which regulator and wastegate do u recomend? (Marc)
road race engineering has tial 35mm wastegates for about $225 shipped. the aem fpr works fine. overboost has them cheap.
Old Jul 25, 2001 | 05:33 PM
cliqueSI's Avatar
New User
I would go with the Tial Wastegate and the new SARD Fuel Pressure Regulator.
Old Jul 25, 2001 | 09:55 PM
Default Re: which regulator and wastegate do u recomend? (cliqueSI)
ok well TiAL is almost a defenet i am thinkin that i might go with the vortech unit.
Old Jul 25, 2001 | 10:01 PM
bigTom's Avatar
i knew u were up to something!
Old Jul 26, 2001 | 11:19 AM
Smashback's Avatar
Default Re: which regulator and wastegate do u recomend? (pellie)
Got mine for $205 shipped I'll try to remember the name of the shop. The guy's name is Wayne. He was really cool and got me the good deal
Old Jul 26, 2001 | 11:31 AM
Liltrix's Avatar
Default Re: which regulator and wastegate do u recomend? (mplex2000)
Hey Myplex is that Fast Track Motorsports,
Old Jul 26, 2001 | 01:55 PM
4dGSR at work's Avatar
Default Re: which regulator and wastegate do u recomend? (Liltrix)
aeromotive fpr or paxton
and
tail 35mm would do the trick
3.88 bar??? or something like that abut 6-7 psi
Old Aug 4, 2001 | 04:42 PM
integ94's Avatar
New User
Yes Liltrix(Mr. Jones) it is Fast Track Motorsports.
http://www.fasttrackmotor.com
sales@fasttrackmotor.com
90teg
Apr 1, 2006 05:13 PM
sleepyhamsterlx
Apr 6, 2004 01:03 PM
boosted hybrid
Oct 16, 2002 09:49 PM
BlackGSR
Apr 16, 2002 07:44 AM
XforgivenX
Sep 25, 2001 05:26 PM
