Best place to tap for vac source
Old Jun 6, 2003 | 10:43 AM
swlabhot's Avatar
Default Best place to tap for vac source
Which is the IDEAL place to tap the vac for an external wastegate? FPR, brake booster, etc...?
Old Jun 6, 2003 | 10:47 AM
JM Performance's Avatar
Default Re: Best place to tap for vac source (swlabhot)
i go off of the compressor housing....gives the fastest response.
Old Jun 6, 2003 | 10:57 AM
swlabhot's Avatar
I'm getting irregular boost patterns, as in sometimes I get a lot more power and torque and other times not much at all. I can't seem to pinpoint when it occurs, one day it would run sweet and the next day not so good so I'm starting to troubleshoot at the wastegate before I go too deep.
At the moment I have everything tapped into the fpr (bov, boost gauge, wastegate), so I'm trying to experiment with different sources to see if its the wastegate playin games
Old Jun 6, 2003 | 11:02 AM
Kwuaymaikrup's Avatar
To the top.....I was wondering the same thing. I have my intake mani tapped and fitted with NPT barbed fittings. All three sources come from the mani. Should I see any probems with this??? I've heard boost spiking issues but am still unclear. Can anyone clear this up for us??? Thanks,
-Ryan
Old Jun 6, 2003 | 01:50 PM
InTeGrA B18b1's Avatar
try your brake booster for your wastegate or you could try the compressor. if your compressor doesnt have one, i have heard of putting a tube in your charge pipe as a vacuum source.
Old Jun 6, 2003 | 06:48 PM
swlabhot's Avatar
Default Re: Best place to tap for vac source (InTeGrA B18b1)
Where does everyone else tap theirs?
zach1288
Jul 8, 2010 02:39 PM
turbo sol
Mar 1, 2009 08:47 AM
PooOnMyShoe942
Sep 30, 2005 04:50 PM
2muchPSI
Nov 22, 2003 02:34 PM
VTEC-DA
Sep 13, 2002 02:01 PM
