finished my project... having problems.. :(
Old Jun 5, 2003 | 06:17 PM
queez's Avatar
Default finished my project... having problems.. :(
hey guys just finished my boost project, this is what i've got,
prescision sc34
2.5" PIPING
inlinepro mani
tial wastegate
spearco intercooler
blitz bov
apexi avcr
doing the hack
ngkre11 plugs
2.5" downpipe
greddy exhaust.
only seems like i can hit .50 bar boost.. not even with the avcr off i cant hit anything power seems like?? also the blitz bov sounds like a whisper not like the powerful pssshhht i would like it to? any reason why?? or what bov would make that great sound??
Old Jun 5, 2003 | 06:24 PM
c1hatch's Avatar
Default Re: finished my project... having problems.. :( (queez)
is that what your wastegate spring is??? i havent really messed with an avcr, but is has a selflearning thing where you gotta make boosted runs etc... & check your duty cycle.
Old Jun 5, 2003 | 06:33 PM
queez's Avatar
Default Re: finished my project... having problems.. :( (c1hatch)
my duty cycle is at 50% and the spring is a 6lb spring..
Old Jun 6, 2003 | 07:54 AM
IntegraFanatic's Avatar
.5 bar is 7 (+/-) psi.
your BOV wont be loud because you are running such low boost. Try boosting 15psi and it'll be loud
Old Jun 6, 2003 | 07:59 AM
SiRkid's Avatar
Default Re: finished my project... having problems.. :( (IntegraFanatic)
he should hear it at 7....it shouldnt be just a whisper.
hrmmmm
Old Jun 6, 2003 | 08:14 AM
DeepSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraFanatic &raquo;</TD></TR><TR><TD CLASS="quote">.5 bar is 7 (+/-) psi.
your BOV wont be loud because you are running such low boost. Try boosting 15psi and it'll be loud</TD></TR></TABLE>
If you are hitting .5 bar then you are hitting your wastegate spring then. You might want to adjust the spring on the BOV and it may get a little bit better.
Old Jun 6, 2003 | 10:22 AM
Default Re: finished my project... having problems.. :( (SiRkid)
pressure test the system and check for leaks
Old Jun 6, 2003 | 10:36 AM
turbod16y8's Avatar
yea try adjusting your bov....maybe its leaking under boost.
Old Jun 6, 2003 | 07:01 PM
queez's Avatar
Default Re: finished my project... having problems.. :( (turbod16y8)
is it that my precision sc34 turbo is too big??? shouldnt it hit full boost at like 4k rpm?? if i'm using the avcr.. should i set the duty cycle higher to compensate?? also putting the screw deeper in the bov does that seal it more or open it up more??
and how could i test for a pressure test on the system?
lsv_ 973
Jul 11, 2011 05:17 AM
SIXTY-1HATCH
Oct 10, 2009 10:42 AM
EARLdaSQUIRREL
Jul 25, 2005 03:47 PM
AF-b16a1
Aug 11, 2004 11:30 PM
DIRep972
Nov 23, 2001 05:17 PM
