ECU questions??
Old Jul 16, 2001 | 09:14 AM
ringgold's Avatar
Default ECU questions??
I have an 98 Civic EX is worth it to get one of those ecu jumpers and convert it from an obd-II to an obd-I. Im a little confused on if I should do this and put a rechipped obd-I ecu in my car or save a little money and get the obd-II rechipped. I have found a few places that can do it now but it is a one time only thing no more rechipping after the first time. I have a different cam, and some other work done and I know that the factory rev limit should probably be taken out. What should I do.
Old Jul 16, 2001 | 09:42 AM
sohc_boy's Avatar
Default Re: ECU questions?? (ringgold)
actually i was wondering the same thing as u, i know g-force can chip the obd2 ecu's now. i was thinking of having my rev limit removed and than using a super afc or field fuel controller to fine tune the map.
[Modified by sohc_boy, 1:42 PM 7/16/2001]
Old Jul 16, 2001 | 11:09 AM
WAFFLES's Avatar
WHY DO YOU WANT TO FO TO OBD1 SO BAD.I KNOW KATMAN AND LOCASH CAN CHIP IT TOHUGH. CHECK THOSE GUYS OUT
Old Jul 16, 2001 | 12:32 PM
ringgold's Avatar
Default Re: ECU questions?? (WAFFLES)
I would like the rev limit and speed limit removed what does g-force charge to rechip the obd-II. I know of only two or three places that rechip the obd-II's.
Old Jul 16, 2001 | 05:39 PM
t's Avatar
t
Actually there are lots of places that chip OBD2 ecus. Its just the cost that turns those away to OBD1 (You could find a Mugen copy OBD1 chip for $50).
IMO-it is better to chip the OBD2 ecu, (Its like comparing your desktop computer, Would you want to reprogram your older, slower pentium 2 or your faster processing pentium 4?)
Old Jul 17, 2001 | 04:23 AM
sohc_boy's Avatar
my friend said it cost 300 to do the obd2 ecu, not to sure if that is a reliable source or not
ITS_Dunn
16
Oct 2, 2004 01:16 PM
AIWFCIATR
Jul 22, 2004 11:37 PM
gumbybum
Mar 28, 2003 09:27 AM
94dxt
Mar 26, 2003 03:29 PM
ringgold
Jul 18, 2001 11:48 AM
