if i am using hondata, will i need checkvalves or a missing link?
Old May 28, 2003 | 10:38 PM
crx1856's Avatar
Default if i am using hondata, will i need checkvalves or a missing link?
as the title states
Old May 28, 2003 | 10:39 PM
Bspec18's Avatar
Default Re: if i am using hondata, will i need checkvalves or a missing link? (crx1856)
no
Old May 28, 2003 | 11:10 PM
VaporTrail's Avatar
New User
absolutely not
Old May 29, 2003 | 12:13 AM
EVOLMTR's Avatar
Default Re: if i am using hondata, will i need checkvalves or a missing link? (VaporTrail)
that's the badass thing about hondata you don't have to worry about none of that bs...
Old May 29, 2003 | 04:08 AM
h22 ef's Avatar
Default Re: if i am using hondata, will i need checkvalves or a missing link? (EVOLMTR)
if you are boosting over 12psi get a 3bar map sensor
Old May 29, 2003 | 05:12 AM
DragEG6 FI's Avatar
Default Re: if i am using hondata, will i need checkvalves or a missing link? (h22 ef)
An upgraded in-tank fuel pump is most likely needed though.
Old May 29, 2003 | 07:17 AM
drvfast's Avatar
no
Old Nov 2, 2004 | 05:06 PM
Pssst!'s Avatar
Default Re: if i am using hondata, will i need checkvalves or a missing link? (drvfast)
What about the FMU from a Revhard Kit?
Old Nov 2, 2004 | 05:10 PM
PrettyLude's Avatar
the fmu is for a starter kit, and should not exceed 7 psi
Old Nov 2, 2004 | 05:11 PM
johnmay19's Avatar
Default Re: (PrettyLude)
No to the fmu also.
Old Nov 2, 2004 | 05:12 PM
Pssst!'s Avatar
Default Re: if i am using hondata, will i need checkvalves or a missing link? (Pssst!)
Searched with diff. words and found the answer...NO.
Old Nov 2, 2004 | 05:15 PM
Pssst!'s Avatar
So for fuel add ons all that would be need is a adjustable FPR and a Fuel Pressure Gauge with hondata, Correct?
Modified by Pssst! at 6:41 PM 11/2/2004
Old Nov 2, 2004 | 06:00 PM
johnmay19's Avatar
You mainly just need the pump, but a regulator will help.
Old Nov 2, 2004 | 07:46 PM
Pssst!'s Avatar
Default Re: if i am using hondata, will i need checkvalves or a missing link? (johnmay19)
Gracias johnmay19
Old Nov 2, 2004 | 09:45 PM
dumpeDc2's Avatar
I'm a Jackass
get bigger injectors
Old Nov 2, 2004 | 10:26 PM
SOHC_MShue's Avatar
Default Re: if i am using hondata, will i need checkvalves or a missing link? (dumpeDc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dumpeDc2 &raquo;</TD></TR><TR><TD CLASS="quote">get bigger injectors </TD></TR></TABLE>
definantely need these
Old Nov 2, 2004 | 11:13 PM
island4drtypeR's Avatar
No check valves or missing links. You want the Hondata to read manifold pressure acurately.
Use bigger injectors, 255lph in-tank fuel pump, fuel pressure regulator, and a GM 3 bar map sensor.
Modified by island4drtypeR at 3:36 PM 11/3/2004
Old Nov 3, 2004 | 03:05 AM
johnmay19's Avatar
Default Re: if i am using hondata, will i need checkvalves or a missing link? (island4drtypeR)
Thats right, injectors slipped my mind.
respectblades
Feb 1, 2005 06:00 PM
Import_Fan
Sep 13, 2004 03:04 PM
angela_itr
Jun 26, 2004 11:39 AM
JiggyKooAndy
Oct 28, 2002 05:44 AM
_Shadow_
Nov 27, 2001 03:30 PM
