if i am using hondata, will i need checkvalves or a missing link?
Re: if i am using hondata, will i need checkvalves or a missing link? (VaporTrail)
that's the badass thing about hondata you don't have to worry about none of that bs...
Re: if i am using hondata, will i need checkvalves or a missing link? (Pssst!)
So for fuel add ons all that would be need is a adjustable FPR and a Fuel Pressure Gauge with hondata, Correct?
Modified by Pssst! at 6:41 PM 11/2/2004
Re: if i am using hondata, will i need checkvalves or a missing link? (dumpeDc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dumpeDc2 »</TD></TR><TR><TD CLASS="quote">get bigger injectors </TD></TR></TABLE>
definantely need these
Re: if i am using hondata, will i need checkvalves or a missing link? (crx1856)
No check valves or missing links. You want the Hondata to read manifold pressure acurately.
Use bigger injectors, 255lph in-tank fuel pump, fuel pressure regulator, and a GM 3 bar map sensor.
Modified by island4drtypeR at 3:36 PM 11/3/2004
