still white comming from exghaust side of my turbo.....
Old May 21, 2003 | 08:32 AM
boostedlude3g's Avatar
Default still white comming from exghaust side of my turbo.....
Last time I posted this up I had changed my head gasket just in case. And now I had the turbo rebuilt and its still smoking from the turbo. Oil is leaking from the exghaust side of the turbo where the exghaust port bolts to the turbo housing and its buring off going down the exghaust pipe. Any Ideas would be helpful. I have a lot of trouble believing the motor is spraying oil out of the exghaust like that cause, its a lot of oil. (about 1Q every 50 miles)
P.S. I will be getting a hold of the guy that rebuilt my turbo today.
Thanks,
Wayne
Old May 21, 2003 | 03:22 PM
Marauder's Avatar
Default Re: still white comming from exghaust side of my turbo..... (boostedlude3g)
Is your oil feed or oil return line leaking in that area? Or something cracked?
Old May 21, 2003 | 04:38 PM
Pritos's Avatar
New User
Default Re: still white comming from exghaust side of my turbo..... (Marauder)
bad fitting connection? sounds like oil burning on the center section. oh duh, I just reread your post, it IS oil burning.
perhaps a bad rebuild. oil shouldnt leak that much. heh
is the oil feed an old line? maybe the rubber line inside is broken. is your oil return line kinked?
Old May 21, 2003 | 05:24 PM
Default Re: still white comming from exghaust side of my turbo..... (Pritos)
I wouldn't think if the feed line was kinked it would do that, but I just replaced the drain line. Unless its blocked in the fitting in to the oil pan, cause when I replaced the drain line I pulled it off the oil pan end (first) and a lot of oil came out of the line which I would think it should have been empty, right?
I checked the drain line and it was clear. I started it up and oil started to seep from the flange on the exghaust side of the turbo again.
PLEASE HELP!
Modified by boostedlude3g at 10:53 PM 5/21/2003
Old May 22, 2003 | 04:46 AM
come on guys I need help.
blk96coup
Jul 28, 2008 11:33 AM
bboyfreeze
Apr 2, 2007 08:38 PM
Blkteg97
Nov 16, 2004 08:04 AM
slo_crx
Oct 6, 2004 08:30 AM
Elite Hatch
Oct 20, 2002 05:43 AM
