What tap to use on block. for oil feed line.
Old May 16, 2003 | 01:48 PM
StreetRacnGsR
Guest
Posts: n/a
Default What tap to use on block. for oil feed line.
What tap to use on a oil feed line off the back of the block? I need to tap it..
Old May 16, 2003 | 04:32 PM
scttydb411's Avatar
Default Re: What tap to use on block. for oil feed line. (StreetRacnGsR)
did you already screw something in it and screw it up? it's an 1/8 bspt thread. if you use any other type of fitting you will strip it out or if you try to tighten the crap out of it. many people strip it out trying to force a 1/8 npt male fitting into it. if you are wanting a fitting for it sunpro and autometer make 1/8 bspt male to 1/8 npt female fittings so that you can run your oil lines.
Old May 16, 2003 | 05:02 PM
StreetRacnGsR
Guest
Posts: n/a
Default Re: What tap to use on block. for oil feed line. (scttydb411)
No i didnt screw it up. Yet lol i hope i dont i have a whole set of snap on tap and die kit. has alot of differant ones. Thank for your help i gonna look and see if i have it i should.
Old May 16, 2003 | 07:41 PM
Kutsuju_SLeePER's Avatar
Damn, im gonna try to Download pics from my caemra to help ya out. Good luck man.
Old May 17, 2003 | 10:18 AM
StreetRacnGsR
Guest
Posts: n/a
Default Re: What tap to use on block. for oil feed line. (Kutsuju_SLeePER)
Thanks Man Pics will help alot. Apricate it.
Old May 19, 2003 | 05:35 PM
Flamenco-T's Avatar
you need a BSPT to NPT adapter, you don;t need to tap anything, as amatter fact, DON'T. Not when the motor is still in. if you;re having any problem, let me know
stan
Old May 19, 2003 | 05:51 PM
scttydb411's Avatar
Default Re: What tap to use on block. for oil feed line. (Flamenco-T)
use pretty much those parts, but i would mount the t on the firewall and just run a line to the bspt adapter to relieve weight/stress on the mount in the block. it also makes it easier to put it in w/o messing it up.
Old May 19, 2003 | 06:02 PM
Flamenco-T's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scttydb411 &raquo;</TD></TR><TR><TD CLASS="quote">use pretty much those parts, but i would mount the t on the firewall and just run a line to the bspt adapter to relieve weight/stress on the mount in the block. it also makes it easier to put it in w/o messing it up.</TD></TR></TABLE>
if you have a BSPT adapter, you will not put any stress on the block. if it's the incorrect thread, then yeah, you are putting stress on it.
think about your exhaust manifold or intake manifold or PS bracket. they're all uses a correct thread, therefore, you'll never put too much stress on it
FYI
Old May 22, 2003 | 12:03 PM
Burke's Avatar
Banned
i got about 3 feet of stainless line, but nothing else. Where can i find this adapter that's shown in the pic?? I live about 30 min away from summit, so that's what i was gonna try, but i am unsure what to get. I have a t3/t4 from a drag kit (i think)? do you know what size fitting it is into the turbo. I got my coolant lines and return line figured out, its just this feed line is giving me some trouble.
Thanks for your help
Old May 22, 2003 | 05:41 PM
r7's Avatar
r7
Default Re: What tap to use on block. for oil feed line. (Burke)
what is the other one in the picture? not the send line for the turbo, but the other one
will i get an engine code if i disconnect that?
Old May 22, 2003 | 06:45 PM
mos's Avatar
mos
Default Re: What tap to use on block. for oil feed line. (r7)
Thats for the dummy light on your dash. You can just leave it disconnected. By the time that light goes on, your engine is probably already gonna be damaged anyhow. Most people leave it hooked up tho.
Old May 23, 2003 | 07:17 PM
r7's Avatar
r7
Default Re: What tap to use on block. for oil feed line. (mos)
will i get an ecu code if i disconnect?
Old May 27, 2003 | 09:02 PM
Nature's Renewal's Avatar
what is the smallest ss oil line to use on a turbo? i think i bought one too small in diameter
Old May 27, 2003 | 09:03 PM
b18bturbo's Avatar
Default Re: (krskid)
-3 or -4 is what most people use
Old May 27, 2003 | 09:09 PM
GOLDBERG's Avatar
Default Re: (b18bturbo)
i';d suggest using the GE oil feed/vtec kit...make it ALOT easier....lil more pricey..but alot easier..
Old May 27, 2003 | 09:17 PM
LJR-LUDE01's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scttydb411 &raquo;</TD></TR><TR><TD CLASS="quote">did you already screw something in it and screw it up? it's an 1/8 bspt thread. if you use any other type of fitting you will strip it out or if you try to tighten the crap out of it. many people strip it out trying to force a 1/8 npt male fitting into it. if you are wanting a fitting for it sunpro and autometer make 1/8 bspt male to 1/8 npt female fittings so that you can run your oil lines.</TD></TR></TABLE>
don't get a sunpro fitting. I got one and when my brother was turning the fitting it broke. thank god it wasn't all the way in.
A.E Motoring
Mar 25, 2006 10:08 PM
DriveSlowHomie
Jul 16, 2005 08:54 PM
FOrSfEd
Aug 13, 2004 12:03 PM
aracer69
Sep 9, 2003 02:04 PM
Junglesnake
Jul 31, 2003 07:25 PM
