would it matter
Old Sep 9, 2003 | 01:56 PM
aracer69's Avatar
Default would it matter
which side the oil inlet or outlet is for the turbo....usually the bigger opening is for the bottom side correct? will this effect the turbo's performance
Old Sep 9, 2003 | 02:04 PM
InfamousRS's Avatar
Default Re: would it matter (aracer69)
ahhh...it doesn't matter...just use a -10an supply, and -3 return
on me....
the large hole is the return (which goes to your oil pan). normally you use a -10AN braided line for that.
The small hole is the supply hole (which goes from the oil supply of your choice on your block to the the turbo). This like is normally a -3 AN line.
boriquabdygurl
Feb 18, 2007 07:04 AM
88da3
Feb 1, 2006 03:47 PM
alfee
Jun 28, 2004 04:10 PM
Prelude91siT
Jan 19, 2004 06:24 AM
pelotudo
Aug 18, 2002 10:15 PM
