help really quick on oil feed question...installing rite now
Old Jul 16, 2005 | 04:37 PM
DriveSlowHomie's Avatar
Default help really quick on oil feed question...installing rite now
im encountering a problem(i thinkk) with fasturbo oil feed line...when u put the line on the fitting, should it snug the wire tight too, when nut is tight?...how come the nut on the line is all the way in the fitting but the wire is still freely turning?...all the other lines(compression/pressure) i dealt with b4 snugs the lines tight too when its all the way...tell me i got the right parts
Old Jul 16, 2005 | 05:03 PM
Islandspeed's Avatar
Default Re: help really quick on oil feed question...installing rite now (cmGSR916)
Sounds like there's something wrong with the fitting... Did you try it wrench tight? Some thimes they won't sung up if only hand tight.
Old Jul 16, 2005 | 08:49 PM
Default Re: help really quick on oil feed question...installing rite now (Islandspeed)
got it to work good...i shaved it a bit...i kinda encountered another prob though...the fitting that goes into the block doesnt go in so easy...i didnt even put in the silver piece in the block cause it dont fit...i just put in the brass piece and it only goes in like 2 rounds...hopefully not oil leaks on me
Old Jul 16, 2005 | 08:54 PM
flip1199's Avatar
make sure to use some teflon tape
toolowsol
Aug 7, 2004 06:17 PM
jspek29
Jun 3, 2003 02:15 PM
StreetRacnGsR
May 27, 2003 09:17 PM
integranator
Apr 24, 2003 09:42 PM
MikeMAN
Jul 2, 2002 09:25 PM
