Turbo for my b16, which?
Old May 11, 2003 | 04:48 PM
shotty's Avatar
Default Turbo for my b16, which?
Ok, right now I am running the greddy tdo4-15g with a log style manifold and the greddy dp that comes in the same kit on my B16. I have a blitz 3mm head gasket, blockguard, Apexi AVC-r, Starion FMIC, dsm 450cc injectors, and the Zdyne Gold SECU running this on an otherwise stock block. I am planning on upgrading to a t3/t4 hybrid turbo, equal length manifold, and a larger downpipe. I need to know what trim turbine and compressor to run. I am only planning on running 1 bar boost at most. Also, has anyone had any experiences with the ssautochrome manifold -> http://cgi.ebay.com/ebaymotors...=6770
I would not use their downpipe(2.25"), they said they would sell me just the mannifold for $225. Let me know!!!!
Old May 11, 2003 | 04:52 PM
DaveF's Avatar
Default Re: Turbo for my b16, which? (shotty)
that is the manifold that everyone has probelms with cracking.
go with inline pro or max rev, wont have problem cracking and is clean.
as for turbo...are ya gonna build bottom end or plan on in future??
go with something like t3/to4e. 58 trimand .63 a/r ratio
also get a prescion turbo..look around on the site and check evryone else's setup, make your desion from there.
Modified by 2.2Lcivic at 11:27 PM 5/11/2003
Old May 11, 2003 | 04:55 PM
shotty's Avatar
Default Re: Turbo for my b16, which? (2.2Lcivic)
Im not planning on rebuilding unless I blow it up. Im guessing the people who crack them headers are not bracing them. I have no problem with bracing the manifold and turbo to the block for extra support. Keep the opinions coming! Thanks..............
Old May 11, 2003 | 05:00 PM
DaveF's Avatar
ya, you shouldnt have a problem if you brace it. good luck
Old May 11, 2003 | 07:23 PM
b16ahybrid's Avatar
Is this mostly a street car?
I'm runing a t3t40E 57 trim .63 A/R and i really like it.At one bar this turbo should be in it's sweet spot (don't have a graph but if i remember rite thats rite in the sweet spot)..So will recomend a t3 60-1 but it comes down to driving style and use.
Old May 11, 2003 | 07:49 PM
shermanyang's Avatar
Default Re: Turbo for my b16, which? (b16ahybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16ahybrid &raquo;</TD></TR><TR><TD CLASS="quote">Is this mostly a street car?
I'm runing a t3t40E 57 trim .63 A/R and i really like it.At one bar this turbo should be in it's sweet spot .</TD></TR></TABLE>
Same turbo I'm running and I love it! but I'm running it on a built LS.
Old May 11, 2003 | 09:11 PM
InTeGrA B18b1's Avatar
Default Re: Turbo for my b16, which? (shermanyang)
thats what i got hopefully itd be in end of this month
Old May 11, 2003 | 09:17 PM
rainmanEK's Avatar
big strong guy
Default Re: Turbo for my b16, which? (InTeGrA B18b1)
I decided to go with the SC50 .63ar for my B16a2!!
Eric
Old May 12, 2003 | 06:20 AM
shotty's Avatar
Default Re: Turbo for my b16, which? (rainmanEK)
It is for a street car, BUT it is not my daily driver. How quick are you to full boost with the t3t40E 57 trim .63 A/R? With what setup? What do you guys think about the greddy 15g turbo on a b16? I never really checked into the flow rates and all. How does it compare with the t3t40E 57 trim .63 A/R?
Old May 12, 2003 | 04:22 PM
shotty's Avatar
How about a Garret TA34 T3T04E -57 trim, .60ar compressor housing, .48ar exhaust housing?
Old May 12, 2003 | 09:09 PM
b16ahybrid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shotty &raquo;</TD></TR><TR><TD CLASS="quote">It is for a street car, BUT it is not my daily driver. How quick are you to full boost with the t3t40E 57 trim .63 A/R? With what setup? What do you guys think about the greddy 15g turbo on a b16? I never really checked into the flow rates and all. How does it compare with the t3t40E 57 trim .63 A/R?</TD></TR></TABLE>
The t3t4 will out flow the greddy 15g. i'm at full boost about 4,500rpm.
starts to spool about 2500rpm
00bluecivicsi
Nov 8, 2009 08:56 PM
mra4886
Aug 24, 2006 04:06 PM
JDMlyfestyle
May 10, 2005 07:39 PM
lone
Mar 23, 2005 06:56 PM
redstdcivic
Feb 12, 2004 07:52 AM
