Turbo for my b16, which?
Ok, right now I am running the greddy tdo4-15g with a log style manifold and the greddy dp that comes in the same kit on my B16. I have a blitz 3mm head gasket, blockguard, Apexi AVC-r, Starion FMIC, dsm 450cc injectors, and the Zdyne Gold SECU running this on an otherwise stock block. I am planning on upgrading to a t3/t4 hybrid turbo, equal length manifold, and a larger downpipe. I need to know what trim turbine and compressor to run. I am only planning on running 1 bar boost at most. Also, has anyone had any experiences with the ssautochrome manifold -> http://cgi.ebay.com/ebaymotors...=6770
I would not use their downpipe(2.25"), they said they would sell me just the mannifold for $225. Let me know!!!!
Re: Turbo for my b16, which? (shotty)
that is the manifold that everyone has probelms with cracking.
go with inline pro or max rev, wont have problem cracking and is clean.
as for turbo...are ya gonna build bottom end or plan on in future??
go with something like t3/to4e. 58 trimand .63 a/r ratio
also get a prescion turbo..look around on the site and check evryone else's setup, make your desion from there.
Modified by 2.2Lcivic at 11:27 PM 5/11/2003
Re: Turbo for my b16, which? (2.2Lcivic)
Im not planning on rebuilding unless I blow it up. Im guessing the people who crack them headers are not bracing them. I have no problem with bracing the manifold and turbo to the block for extra support. Keep the opinions coming! Thanks..............
Is this mostly a street car?
I'm runing a t3t40E 57 trim .63 A/R and i really like it.At one bar this turbo should be in it's sweet spot (don't have a graph but if i remember rite thats rite in the sweet spot)..So will recomend a t3 60-1 but it comes down to driving style and use.
Re: Turbo for my b16, which? (b16ahybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16ahybrid »</TD></TR><TR><TD CLASS="quote">Is this mostly a street car?
I'm runing a t3t40E 57 trim .63 A/R and i really like it.At one bar this turbo should be in it's sweet spot .</TD></TR></TABLE>
Same turbo I'm running and I love it! but I'm running it on a built LS.
Re: Turbo for my b16, which? (rainmanEK)
It is for a street car, BUT it is not my daily driver. How quick are you to full boost with the t3t40E 57 trim .63 A/R? With what setup? What do you guys think about the greddy 15g turbo on a b16? I never really checked into the flow rates and all. How does it compare with the t3t40E 57 trim .63 A/R?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shotty »</TD></TR><TR><TD CLASS="quote">It is for a street car, BUT it is not my daily driver. How quick are you to full boost with the t3t40E 57 trim .63 A/R? With what setup? What do you guys think about the greddy 15g turbo on a b16? I never really checked into the flow rates and all. How does it compare with the t3t40E 57 trim .63 A/R?</TD></TR></TABLE>
The t3t4 will out flow the greddy 15g. i'm at full boost about 4,500rpm.
starts to spool about 2500rpm
00bluecivicsi
11-08-2009 08:56 PM
