Wiring Vtec in 92 civic w/ b17a motor *pressure switch *Intermediate shaft
Old May 9, 2003 | 05:46 AM
SpoonSportsJunkie's Avatar
Default Wiring Vtec in 92 civic w/ b17a motor *pressure switch *Intermediate shaft
Did a search.. and I am not sure my Q? was thoroughly answered.
*I noticed the ecu pinouts have two for Vtec pressure switch! one is b15 and
the other is D6. I know that the Vtec pressure swich has two wires.. I have heard that one of them is ground.. but which one? the top wire or bottom (the switch positions the wires in a vertical line! ) And then there is the issue of The remaining wire! does that go to the B15 pinout or the D6 pinout?????
What options are there for the mid -intermediate shaft on a b16a trans mission with a B17a engine block (same as b16a1 & 2) I presume to use the delsol or jdm b16a3 shaft.. but will it mount to the b17a/b16a1 block?
Some one please help who is experienced in this matter!
Old May 9, 2003 | 09:02 AM
Hybrid96EK's Avatar
Default Re: Wiring Vtec in 92 civic w/ b17a motor *pressure switch *Intermediate shaft (SpoonSportsJunkie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoonSportsJunkie &raquo;</TD></TR><TR><TD CLASS="quote">Did a search.. and I am not sure my Q? was thoroughly answered.
I am not sure of the wiring off the top of my head. I used a 94 teg intermediate shaft on my B17 swap and it worked fine. Any of the 94+ teg intermediate shafts should work fine as well as the 99-00 Si ones. I will check on the wiring for you to tell you what you need. Are you hooking up the knock sensor as well?
Old May 13, 2003 | 02:45 PM
roc's Avatar
roc
on the pressure switch the blac wire gets a ground ,the other 1 goes to d6
Freya Franco
Engine Management and Tuning
Dec 13, 2017 10:49 PM
Outkast95LS
Jun 3, 2007 07:58 PM
NSfit
Dec 29, 2006 12:17 PM
iNERtIA
Apr 3, 2006 09:42 PM
eg6T
Nov 7, 2004 06:20 PM
