Alignment question?
Old Apr 21, 2003 | 07:51 PM
civic_91's Avatar
Default Alignment question?
Hey i took my steelies off my car and put my 16's on with brand new rubber... i thought i might need an alignment but the car doesnt vibrate or pull in any way ? should i still take it down or will i be ok? the tires now have about 2000 kms on them and look to be wearing normally?
Old Apr 21, 2003 | 08:01 PM
yellow eg's Avatar
Default Re: Alignment question? (civic_91)
you need to align only if u change suspension bushings or dissasamble the suspension , not needed when changing rims or brakes..
Old Apr 25, 2003 | 07:19 AM
tpr's Avatar
tpr
Default Re: Alignment question? (yellow eg)
If you want a quick feel good, pull astring from the back of the car across the rear tire then pull it tight and see if the distances to the string front and rear of front tire are the same on both sides. No this does take care of a bent rim or bulging tire sude wall but it will let you know if it is grossly off. The toe should be 0.0 -1 degree + 0.0 degrees. If any thing slightly toed in..
egfanatic
Jan 23, 2015 07:35 AM
PunchedGuava
23
Apr 26, 2013 08:28 AM
ekcivic9
Suspension & Brakes
19
Oct 16, 2007 01:19 PM
EGBuddy
Apr 22, 2006 11:19 AM
R249
May 19, 2004 08:00 PM
