b17 head fit on gsr block?
Old Apr 10, 2003 | 09:30 AM
EARLdaSQUIRREL's Avatar
official honda whore
Default b17 head fit on gsr block?
well i am pretty sure it fits but i am asking this question for a friend, Will the b17 head bolt right up to a gsr block w/o any problems. thanks alot, the quicker the response the better
Old Apr 10, 2003 | 09:38 AM
ill phil's Avatar
Default Re: b17 head fit on gsr block? (coptzer)
Yes, it's a PR3 head (B16) so it will work, you will need the GSR head bolts though.
Old Apr 10, 2003 | 09:51 AM
Default Re: b17 head fit on gsr block? (ill phil)
thanks, thats all i needed to know, its for ls vtec and it will work just teh same as a gsr head or b16 head right?
Old Apr 10, 2003 | 09:58 AM
monicle's Avatar
dont you mean a gsr head on a b17 block?
Old Apr 10, 2003 | 10:02 AM
ill phil's Avatar
Default Re: b17 head fit on gsr block? (monicle)
Technically it would be a GSR head on a GSR block
But yeah you will have to do the same to the B17 head for LS/VTEC that you would do to any B16/B18 head to make it work.
Old Apr 10, 2003 | 06:11 PM
thanks alot guys, i was 100% about this, but needed ppl to back me up for someone. thanks again guys
Old Apr 10, 2003 | 08:26 PM
sshaikh01's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ill phil &raquo;</TD></TR><TR><TD CLASS="quote">Technically it would be a GSR head on a GSR block
But yeah you will have to do the same to the B17 head for LS/VTEC that you would do to any B16/B18 head to make it work.</TD></TR></TABLE>
I thought you only needed gsr head bolts, gsr timing belt, and water pump and you should be set.
Am i missing something??
Old Apr 11, 2003 | 10:03 AM
4g4me's Avatar
You meen non technically speaking
tech= pr3 head vs p72, b18c1/b17a/b16X...the term GSR to means nothing but a non-technical term used for trim levels.
<U>"Gsr head comes with leather and sunroof"</U>
Old Apr 11, 2003 | 11:06 AM
ill phil's Avatar
Default Re: b17 head fit on gsr block? (4g4me)
Yeah and that's what I was referring to. The car is a GSR, the other car is a GSR. One head is from a GSR, the other block is from a GSR.... and so forth. "Technical" doesn't have to mean numbers wise ***. And to show how serious I was, I even threw in the " ".
graveltravel2
Jul 25, 2009 07:58 PM
rock~1
29
Jun 21, 2006 07:53 AM
SpoonEk253
Apr 14, 2006 04:35 PM
WhaznSiR
Jul 11, 2005 06:18 PM
anti muscle
Jan 5, 2005 06:02 PM
