b17 head fit on gsr block?
official honda whore
well i am pretty sure it fits but i am asking this question for a friend, Will the b17 head bolt right up to a gsr block w/o any problems. thanks alot, the quicker the response the better
Re: b17 head fit on gsr block? (ill phil)
thanks, thats all i needed to know, its for ls vtec and it will work just teh same as a gsr head or b16 head right?
Re: b17 head fit on gsr block? (monicle)
Technically it would be a GSR head on a GSR block
But yeah you will have to do the same to the B17 head for LS/VTEC that you would do to any B16/B18 head to make it work.
thanks alot guys, i was 100% about this, but needed ppl to back me up for someone. thanks again guys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ill phil »</TD></TR><TR><TD CLASS="quote">Technically it would be a GSR head on a GSR block
But yeah you will have to do the same to the B17 head for LS/VTEC that you would do to any B16/B18 head to make it work.</TD></TR></TABLE>
I thought you only needed gsr head bolts, gsr timing belt, and water pump and you should be set.
Am i missing something??
You meen non technically speaking
tech= pr3 head vs p72, b18c1/b17a/b16X...the term GSR to means nothing but a non-technical term used for trim levels.
<U>"Gsr head comes with leather and sunroof"</U>
Re: b17 head fit on gsr block? (4g4me)
Yeah and that's what I was referring to. The car is a GSR, the other car is a GSR. One head is from a GSR, the other block is from a GSR.... and so forth. "Technical" doesn't have to mean numbers wise ***. And to show how serious I was, I even threw in the " ".
graveltravel2
07-25-2009 07:58 PM
SpoonEk253
04-14-2006 04:35 PM
