Pics of your oil pan
Old Mar 21, 2003 | 07:29 AM
redsled00's Avatar
Default Pics of your oil pan
I'm just looking for a better way to hook up the oil return line.
Old Mar 21, 2003 | 08:37 AM
ScottEK's Avatar
Default Re: Pics of your oil pan (redsled00)
I'd also like to see some good examples of exactly where to tap the the oil pan on a B series.
Old Mar 21, 2003 | 08:59 AM
Tony Starks's Avatar
Default Re: Pics of your oil pan (beta13)
Doesn't matter if its a b or d, both have to be tapped. Lets see some!
Old Mar 21, 2003 | 09:46 AM
mskibbz-T's Avatar
Default Re: Pics of your oil pan (Tony Starks)
ttt... I wanna see some as well
Old Mar 21, 2003 | 10:35 AM
ladysman's Avatar
Default Re: Pics of your oil pan (mskibbz-T)
Me too.
Old Mar 21, 2003 | 11:14 AM
redsled00's Avatar
Default Re: Pics of your oil pan (ladysman)
Yeah I wanna see some too!
Old Mar 21, 2003 | 12:21 PM
ScottEK's Avatar
All these turbo people and nobody is returning oil, I highly doubt that, I've seen a couple posts before showing proper areas to tap it and some examples that were too low. I believe it's the higher the better right? Because if it was low you would have the same height of oil in the line all the time as there is in the pan.
Old Mar 21, 2003 | 12:46 PM
nd8ch's Avatar
mine leaked the first time...get a mufler shop to weld it and have piece of mind.
Old Mar 21, 2003 | 02:04 PM
asianspeed's Avatar
Default Re: Pics of your oil pan (nd8ch)
Here's mine. It's on a b18b.
This is where/how I placed mine.
[Modified by asianspeed, 1:05 PM 3/21/2003]
Old Mar 21, 2003 | 04:34 PM
accordfreak's Avatar
Default Re: Pics of your oil pan (asianspeed)
kinda blurry but you get the picture
Old Mar 21, 2003 | 07:12 PM
b16 matt's Avatar
Default Re: Pics of your oil pan (accordfreak)
My dad works for Honda and he welded my oil return line on at work and and had it repainted at work. So its oem honda still lol.
Old Mar 22, 2003 | 01:08 PM
QCKGSR's Avatar
Default Re: Pics of your oil pan (b16matt)
higher the better!!
Old Mar 22, 2003 | 01:28 PM
krazy's Avatar
Default Re: Pics of your oil pan (QCKGSR)
i thought if too high it might be obstructed by the baffle or something like that. the windage tray i mean... i dunno one of those things.
and someone posted that hot oil shouldnt hit the crank upon entry so that may be bad. i dunno. any can clarify?
krazy
Old Mar 22, 2003 | 01:36 PM
B18EG6's Avatar
Default Re: Pics of your oil pan (krazy)
here is mine...nice and clean
Old Mar 22, 2003 | 01:59 PM
ZentraediEK's Avatar
Default Re: Pics of your oil pan (B18EG6)
Good Post!
has anyone ever had a problem with the fitting on the oil pan(assuming it's in the middle of the pan) getting in the way of your downpipe? I've been through 3 pans trying to get the damn thing lined up....is it better to be tapped on the deep side or the shallow side?
[Modified by ZentraediEK, 11:00 PM 3/22/2003]
Old Mar 22, 2003 | 02:18 PM
hybrid901's Avatar
Default Re: Pics of your oil pan (ZentraediEK)
Old Mar 23, 2003 | 05:19 PM
Default Re: Pics of your oil pan (hybrid901)
bump for more pics
Old Mar 23, 2003 | 06:15 PM
5thgencivic's Avatar
Old Mar 23, 2003 | 06:43 PM
Bailhatch's Avatar
Default Re: Pics of your oil pan (5thgencivic)
How are you guys finding the bolt on flange style ones are as far as leakage? I just did a weld on one and it has a pin hole that gets the front of the pan a little oily. I think I'll braze the hole shut or use some high temp RTV.
Do you use a gasket w/ RTV or just RTV to seal it? BAcking plate or washers?
thanks
Old Mar 24, 2003 | 09:08 AM
incogNitto's Avatar
Default Re: Pics of your oil pan (Bailhatch)
Off to the driver's side trying to keep it away from the DP. Seems effective so far.
Old Mar 24, 2003 | 10:18 AM
Rain_man's Avatar
New User
Default Re: Pics of your oil pan (incogNitto)
Make sure you put the oil pan fitting in a place where it won't make it hard to put the screws back in that hold the pan in place.
sikid111
Jan 31, 2019 07:14 PM
JDM00SI
Dec 4, 2005 07:22 PM
B18c1turboedEK
Feb 21, 2005 10:32 AM
fandango
Jan 20, 2005 06:20 PM
2SLO
Dec 18, 2003 01:15 PM
