Egt gauge location dp or manifold
Old Mar 10, 2003 | 04:12 PM
slowsi00's Avatar
Default Egt gauge location dp or manifold
ok i am going to get a greddy egt gauge....
i know that the manifold is the best place for the best reading
but i have heard of egt's getting to high melting the probe and then the probe flys into your turbo
so i was thinking the downpipe for saftey reasons but will i get an accurate reading?
Old Mar 10, 2003 | 04:13 PM
dfoxengr's Avatar
Default Re: Egt gauge location dp or manifold (slowsi00)
my friend runs his on the mani...
Old Mar 10, 2003 | 04:21 PM
DeepSi's Avatar
Default Re: Egt gauge location dp or manifold (hybridvteceg)
in the manifold is fine. A lot of people on here run it in the manifold. Also the greddy unit is top notch and wont melt and drop into the turbo
Old Mar 10, 2003 | 11:33 PM
slowsi00's Avatar
Default Re: Egt gauge location dp or manifold (DeepSi)
cool thanks for the replies
Old Mar 11, 2003 | 03:42 AM
BoostedB20A's Avatar
Is the autometer unit prone to melting and falling into the turbo? I have never heard of this before and I am very interested, thanks.
Old Mar 11, 2003 | 04:41 AM
maxpsi's Avatar
Default Re: Egt gauge location dp or manifold (BoostedB20A)
my autometer probe is right behind the turbo in the DP just like the instructions said to install it. Greddy might be different.
Old Mar 11, 2003 | 06:35 AM
civic1990si's Avatar
Default Re: Egt gauge location dp or manifold (maxpsi)
i have an autometer EGT and it install before the turbo in about 3 inch of the head
it is good???
in the instruction, it tell to install it at 2 inch of the head but i could.
Old Mar 11, 2003 | 07:02 AM
NinjaBuc's Avatar
Default Re: Egt gauge location dp or manifold (civic1990si)
Had an Autometer dual channel EGT on my old Supra. The probes were about 6 in away from the exhaust ports and just fine. I would think a probe designed to read temps in the 1600F range will be fine in the mani. If your temps get hot enough to melt the probe, you have bigger problems. my friend. Besides, post turbo EGT 's aren't as accurate as manifold temps.
Josh
Old Mar 11, 2003 | 07:27 AM
greekspeed's Avatar
i have mone on the manifold.... on cylinder 1
Old Mar 11, 2003 | 08:11 AM
Default Re: Egt gauge location dp or manifold (hybridhatch99)
i would like to know what is the perfect temperature of the mixture???
How hot is really to hot and need to give more fuel.
Thanks
Old Mar 11, 2003 | 08:14 AM
autoEXturbo's Avatar
I have my greddy EGT on my dp.
Old Mar 11, 2003 | 10:41 AM
MachAF's Avatar
Most accurate readings are going to be in the manifold as the turbo absorbs a lot of heat. Therefore a downpipe reading won't be accurate.
Old Mar 11, 2003 | 10:46 AM
Default Re: Egt gauge location dp or manifold (machaf)
I know that's where Inline thought it would be placed best, and I know they do that on most of their cars.
Old Mar 11, 2003 | 10:47 AM
b18bturbo's Avatar
Default Re: Egt gauge location dp or manifold (autoEXturbo)
most of the install i have seen and done are in cyl 3 on the runner approx 6inch away from the port. We have shown the best reading there.
Old Mar 11, 2003 | 10:59 AM
maxpsi's Avatar
I think Autometer say to put the probe behind the turbo on a FI car. Can someone reread the installation instructions about that. I can't find mine.
Josh
The hottest mine has gotten is 1400F on the highway doing like 100mph in fifth. The temperature is relative. If you want to know where you are lean and rich, then get on a dyno, tune your car, and then refer to the EGT on what temps are lean and rich. In this case, it wouldn't matter if you have the probe before or after the turbo. True, if you have the probe behind the turbo then the temperatures for lean and rich will differ from a probe in front of the turbo on the same car. Once again, temperature is all relative. In my case, (probe after turbo) my lean and rich temps will be numerically higher than if I had my probe before the turbo.
Old Mar 11, 2003 | 12:52 PM
i have an autometer kit and they ask in the intruction to install it 2 inch of the cylinder head. I think it's really close. I will recheck to be sure.
Old Mar 11, 2003 | 02:17 PM
maxpsi's Avatar
They have instruction for N/A and FI. Which one says to put the after the turbo?
victoriasamantha
Mid-Atlantic (Sales)
May 25, 2009 06:17 AM
M.A.R.C.
Jul 28, 2002 06:30 PM
TurBoXBirD16
Jul 8, 2002 09:15 AM
snt78
May 29, 2002 10:13 PM
Crxlsturbo
Aug 5, 2001 01:05 PM
