EGT gauge
Old Jun 7, 2002 | 04:25 AM
TurBoXBirD16's Avatar
Default EGT gauge
I am going get a EGT gauge if it's cheap
but i am wondering how i can install it on the exhaust manifold??
i have a greddy kit sohc
please let me know
thanks
Old Jun 7, 2002 | 04:27 AM
DSF's Avatar
DSF
Default Re: EGT gauge (xbird)
Drill and tap...simple as that. My VDO is pretty accurate and responsive. Plus at $125 it won't break the bank
Old Jun 7, 2002 | 04:33 AM
Default Re: EGT gauge (DSF)
just dril and tap?
would i need to use some JB weld??
and that means i need to take out the whole turbo and manifold, right?
is EGT very useful?? hehe
thanks
Old Jun 7, 2002 | 05:54 AM
apexii's Avatar
No not jbweld!
JBweld will not work on a manifold. It will burn and make some wicked toxic fumes! I found this out the hard way on a broken wastegate bolt.
[edit- you want to remove the manifold if you can, metal shavings=bad]
[Modified by apexii, 9:56 AM 6/7/2002]
Old Jun 7, 2002 | 08:41 AM
Default Re: EGT gauge (apexii)
ok
thanks
so just drill and tap
that's it.. thanks
Old Jun 7, 2002 | 09:27 AM
Trigun's Avatar
doh! i put a little around the tap to seal it. guess i have to smell some toxic fumes
Old Jun 7, 2002 | 10:13 AM
DSF's Avatar
DSF
Default Re: EGT gauge (Sayang)
I just took mine to a local shop here and he did it for $75. That was worth if for me not having to take the mani and dp off hehe I hate that!
$75!!! Ouch! should have just drilled and tapped while the engine was running. Exhaust will blow out the shavings
Old Jun 7, 2002 | 11:42 AM
drill when the engine is RUNNING??
what about those metal shavings??
wouldn't that go INTO the turbo and messes up stuff??
Old Jun 7, 2002 | 11:48 AM
inspyral's Avatar
Won't the shavings get stuck in the cat?
tararan's Avatar
exhaust would only blows lil part of the particles... lots of that stuff would still get in the turbo... not worth the risk... dont ever do a half A$$ job with it if you want it to be reliable....
Old Jun 7, 2002 | 11:51 AM
Default Re: EGT gauge (tararan)
sounds like taking it off would be the SAFEST way...
hehehe
thanks
Old Jun 7, 2002 | 12:23 PM
RATEDR's Avatar
Any of you have pics of the gauge in place?
Old Jun 7, 2002 | 02:52 PM
Default Re: EGT gauge (RATEDR)
yea me 2, i want to see where u guys mount ur EGT gauge
i have a dual gauge pod already
and if i get one more gauge, i don't know where to mount it
Old Jun 7, 2002 | 04:48 PM
niedejb's Avatar
Old Jun 7, 2002 | 06:02 PM
lucas569's Avatar
Default Re: EGT gauge (niedejb)
what kind of manifold is that?
Old Jun 7, 2002 | 06:06 PM
turbocoupe's Avatar
Default Re: EGT gauge (lucas569)
Good luck with the MF2.
Old Jun 7, 2002 | 06:28 PM
niedejb's Avatar
Its a FMAX manifold.
Not using the MF2.
Old Jun 7, 2002 | 08:26 PM
shadowdawn's Avatar
My probe is in the SAME place in that picture above... reads as accurate as all these guys having it 1" off their 3rd runner... My egt and all my gauges were installed with the turbo all together at the shop I had this all done at. RPM on queens NYC. I'd recommend them to anyone, they do amazing work.
Old Jun 8, 2002 | 12:16 AM
Default Re: EGT gauge (shadowdawn)
how much would u guys pay for a used blitz EGT gauge? and a temp gauge?
Old Jun 9, 2002 | 12:26 AM
how much?
Old Jun 9, 2002 | 12:39 AM
Pritos's Avatar
New User
yep drill n'tap... but drill with the engine running to blow the shavings as they come.
Old Jul 8, 2002 | 02:20 AM
CalvitoSol's Avatar
what's a vdo gauge? any links? thanx
Old Jul 8, 2002 | 03:40 AM
MiraiZ's Avatar
sell the mf2 now an save for a stand alone!!
Old Jul 8, 2002 | 09:15 AM
DSF's Avatar
DSF
Default Re: EGT gauge (theory48)
http://www.vdona.com/onlinecatalogs/...gaugehome.html
http://www.racerpartswholesale.com/vdo.htm
platinum00
Dec 23, 2004 08:21 AM
slowsi00
Mar 11, 2003 02:17 PM
Ri5e
Sep 10, 2002 12:20 PM
M.A.R.C.
Jul 28, 2002 06:30 PM
RATEDR
Jul 3, 2002 06:34 AM
