can i run 10lbs???
Old Mar 10, 2003 | 10:34 AM
queez's Avatar
Default can i run 10lbs???
ok finished peiceing my turbo kit together ... (waiting for all peices to arrive) ... gonna do RC440 injectors.. and the hack.. can i run 10'bs of boost using this setup?
Old Mar 10, 2003 | 10:41 AM
ridnmyhonda's Avatar
Default Re: can i run 10lbs??? (queez)
thats a little vague, tell us your set up, engine specs...bla bla bla
Old Mar 10, 2003 | 10:58 AM
queez's Avatar
Default Re: can i run 10lbs??? (ridnmyhonda)
ok.. building a custom setup.. very similar to rev hard 2c kit... i talked to the guys at revhard and they said a b16a2 stock can run up to 14psi without damage. and like 11-12 psi daily no problem..(any one doing this???)
my setup
t3/t04e .57 trim .63 a/r
revhard steel (w/ac) mani
revhard 2.5" downpipe
spearco fmic (core) 20x8x3
tial 35mm wastegate with .65 bar
2.5" chargepipes
blitz bov
warlboro 255lph pump
RC 440 injectors
vafc
avcr
victor x intake mani
k just wondering if 10lbs with the hack is ok.. can the hack handle 10lbs with this setup>??
[Modified by queez, 8:15 PM 3/10/2003]
Old Mar 10, 2003 | 12:04 PM
turbosol's Avatar
I run about 11psi daily on my b16, running the afc hack with a btm.
Old Mar 10, 2003 | 12:46 PM
93dx--hatch's Avatar
Default Re: can i run 10lbs??? (turbosol)
how much boost did you run to get 283whp, i don't know what .8 bar is on me
Old Mar 10, 2003 | 01:03 PM
kenbdSi's Avatar
Default Re: can i run 10lbs??? (93dx--hatch)
.8 bar is 11.5 lbs.
Old Mar 10, 2003 | 02:03 PM
simike's Avatar
Default Re: can i run 10lbs??? (kenbdSi)
I'm running 8.5lbs on my stock B16A2 and that is as far as i want to push it. I know alot of people say 10lbs is fine or maybe even more, but when you almost double your HP how much more can the motor really take? I have seen many motors blow at 8-10lbs and if it doesn't i think you are really reducing the life of the motor. Just my .02 cents.
Old Mar 10, 2003 | 02:06 PM
Boltz's Avatar
Default Re: can i run 10lbs??? (simike)
yea ive also seen someone blow a stock engine.... tuning is what matters
Old Mar 10, 2003 | 04:04 PM
boostedsol's Avatar
Yup. I feel the same way, except I'm only running 6.5 psi tuned w/ my aem ems on my b16a3.
Old Mar 10, 2003 | 04:18 PM
BoostedSi's Avatar
Default Re: can i run 10lbs??? (boostedsol)
Get a wideband o2 and make sure your air/fuel is good. I'm sure you can run 10psi daily on stock internals.
Old Mar 11, 2003 | 02:12 PM
simike's Avatar
Default Re: can i run 10lbs??? (BoostedSi)
I'm not worried about tuning, i'm worried about the actual strength of the piston rings/lands under the higher cylinder pressure. I have seen alot of them crack and i don't think tuning has to do with that. If there is a hole in the piston or it has melted i would say you needed to tune it better. I may be wrong, but that is how i see it.
Old Mar 11, 2003 | 02:19 PM
ITR981002's Avatar
I'm running 10psi on my GSR motor with a SMC and 450s. Its putting down 330whp. As stated above, wideband is the key. You can't guesstimate when your running that close to the edge. Good gas also, I wouldn't run 10psi if all you can get is 91 octane.
srg
May 27, 2006 01:13 AM
planeman01
Sep 12, 2005 01:31 PM
gen4h22a
Aug 12, 2004 01:12 PM
NOSED_CRX_VTEC
May 13, 2003 06:18 AM
