EGT install question? Tap or Weld?
Old Jul 27, 2002 | 10:34 PM
M.A.R.C.'s Avatar
Default EGT install question? Tap or Weld?
Is it necessary to weld in a bung on the manifold for an EGT probe? or is just tapping it good enough? I was just thinking. I was reading SCC mag that turbo matrix project they did (I think it's the july issue... the one with the scooby on the front). They tapped it in that install but they said they tapped because it was in a rush, and it would have been better to weld in a bung for it for something that would be driven daily (or something of that nature). How many people have a bung welded and how many just tap it?
Old Jul 27, 2002 | 11:05 PM
Firedrake's Avatar
Default Re: EGT install question? Tap or Weld? (CivicRyda2k)
We just drilled and tapped our SFP manifold on project GSR turbo for the Greddy EGT gauge, and it's had no problems.....if your manifold is thin-walled then welding a bung would be better, but otherwise I don't see any problems with tapping it....
Brian
Old Jul 28, 2002 | 07:48 AM
rice4life's Avatar
Default Re: EGT install question? Tap or Weld? (Firedrake)
if you have a cast iron mani, then you should tap it. but if you have tubular mani then weld.
Old Jul 28, 2002 | 09:57 AM
M.A.R.C.'s Avatar
Brian
Well this is also an SFP manifold but it's a D16 log style. I don't know exactly how thick the walls are though. I think I might end up tapping it. It is possible to weld in the bung later on after tapping it right?
Old Jul 28, 2002 | 02:59 PM
Firedrake's Avatar
Yeah, you can weld a bung on later if you want to, just drill the hole you tapped a little larger and weld a bung on there......you should be fine tapping the manifold though
Brian
Old Jul 28, 2002 | 05:36 PM
ITRfaithful's Avatar
what does it mean by tapping?
Old Jul 28, 2002 | 06:30 PM
BigMoose's Avatar
Default Re: EGT install question? Tap or Weld? (b18newbie)
Tapping cuts female threads in a hole its done with a tap.
Using a die cuts male threads on a rod or bolt its done with a die.
Regards,
BigMoose
Ash J. Williams
Apr 2, 2013 07:37 AM
Tetronious
Jun 30, 2004 07:39 PM
slowsi00
Mar 11, 2003 02:17 PM
B18EG6
Aug 6, 2002 11:18 AM
TurBoXBirD16
Jul 8, 2002 09:15 AM
