What To Use With ZEX Nitrous Kit?????????
Ok in another post I have relized that I want to go with the zex nitrous kit. I have a 94 integra ls with CAI, exhaust, and testpipe. I am going to be use the 55 shot. I am looking to do a dry shot into my intake pretty far away from the TB so the nitrous can spread evenly before it reaches the TB. I am going to purchase the bottle heater with this kit. I have been told to upgrade my spark plugs. Should I do this and what kind should I use. I heard the ZEX plugs have a rough start so I want something that is good all around and can handle the nitrous. Also what other upgrades should I do before installing this kit I want to do it the right way.
if you REALLY want to get the kit installed the right way, get the piston/rod combo just to be safe. But you can install it without of course.
don't have to fool with the timing, just get the ZEX sp and you should have some fun!!!
i still haven't installed mine yet...
Just install it, I wouldn't run anymore than a 55-shot on a stock motor without tuning, but that is personal preference, mount the jet's between 8 - 12 inches from the TB, get some NGK's 1 or 2 steps colder than stock plugs, and you should be set to go.
if youre going o run the zex then just use NGK plugs...go one step colder....you dont need to really upgrade your pistons and rods...theres really no need for that small of an app. Install the jet about 8 inches from the TB and just remember...colder plugs means colder start and lower idle....
NGK BKR7Es will be all that you need to run the Zex kit. Personally, I'd get a purge kit and a bottle warner as well. http://www.speedshop.org has nice stuff.
it also makes sure there is no air/space in the line. that way you have as much nitrous going in at one time as possible. its really bad *** when your about to race someone at a light or something and u purge nitrous all over them IMO. i just think its cool.
It purges the lines of gaseaus nitrous so you get a shot of pure liquid nitrous and there is no delay in delivery.
I always wondered why people put the nozzle like a foot away from the tb...why not put it down by the filter so that it has more time to spread? This would seem like it would also give it better distribution?
The nozzle placement debate has been going on forever. Until I see a back to back dyno showing how different nozzle placement affects hp I stand by the thought that as long as the nozzle is more than 7" away from the TB, then the distribution will be fine.
1. hey, how long have you been sprayin?
2. Just curious what kind of setup you have
3. how big a shot
4. what motor
5. and if you've had any problems in reliability.
3. how big a shot
4. what motor
2. NOS 05030FI direct port kit with teflon lines and NOS purge kit. It's a shitty kit because of the solenoids. Other than that it's a good kit.
3. 75 shot
4. H22A1
5. I blew the seal on my super power shot nitrous solenoid at least 4 times last season. I moved the noids to the raintray and the problem persisted, so I called NOS. They had me send in my blown seals and they sent me out a new noid with a stronger seal. I'm not holding my breath and have money on the side in case I have to get cheater and proshot noids.
1. This will be my second season on the bottle and I have been learning about it for 2 years prior to ever spraying.
I'm in the same boat until I build up a second motor, which won't start for another 6 months and will realistically take a year or two to complete. That's why I take my car to the dyno and get a plot of my AF ratio after every change to the kit.
bobby,
if you need anyhelp, this'll be my 3rd nitrous kid install just call me or ryan up or hit me up on AIM -> i3urton014.
-ryan
-ryan
