CTR Pistons in my B16A
Old Feb 19, 2003 | 02:14 PM
Goldfingiz's Avatar
Default CTR Pistons in my B16A
Hey guys I was wondering what kind of compression I'm looking at with CTR pistons in a stock B16A (obd1). Will the difference be noticeable? Also, they will fit with no fabrication, correct?
Thanks,
Goldfingiz
[Modified by Goldfingiz, 11:15 PM 2/19/2003]
[Modified by Goldfingiz, 11:18 PM 2/19/2003]
Old Feb 19, 2003 | 02:19 PM
sgT's Avatar
sgT
Default Re: CTR Pistons in my B16A (Goldfingiz)
compression 11.1:1
you have to widen the opening in the piston to accomodate the rod.
Next time do a search.
Old Feb 19, 2003 | 02:20 PM
Goldfingiz's Avatar
Default Re: CTR Pistons in my B16A (sgT)
I did do a search. Will they fit on my stock rods?
Old Feb 19, 2003 | 02:22 PM
sgT's Avatar
sgT
like i said you have to open up the piston a little bit
Old Feb 19, 2003 | 02:25 PM
Goldfingiz's Avatar
Thank you Will CTR rods work, or are they longer?
Old Feb 19, 2003 | 02:28 PM
breakneckvtec's Avatar
CTR rods will work fine, they were made for the piston remember. Instead of widening the piston cant you can take a mm from each side of the rod to make the piston fit.
Old Feb 19, 2003 | 02:33 PM
sgT's Avatar
sgT
Default Re: CTR Pistons in my B16A (breakneckvtec)
ctr rods will only work if you use them with a civic type-R crank in a b18c block.
they will not work in a b16a
Master23
Feb 15, 2006 08:56 AM
mist sITR
Feb 25, 2003 10:16 AM
qbsi
Jun 29, 2002 02:32 PM
2 litre EG
Apr 16, 2002 10:53 AM
