Manifold Bolts, What is everyone using? ARP or Stock honda studs?
Old Feb 17, 2003 | 10:27 AM
ladysman's Avatar
Default Manifold Bolts, What is everyone using? ARP or Stock honda studs?
I am finally getting ready to assemble my engine and install the turbo stuff and I wanting to know what everyone uses for manifold fasteners. Bolts (ARP) or stock honda studs. Which would hold better? The head has nothing on it now since it was ported and the new valvetrain installed.
Just thought I would pick everyone's brain on what they use.
Thanks in advance.
Old Feb 17, 2003 | 12:17 PM
ladysman's Avatar
Default Re: Manifold Bolts, What is everyone using? ARP or Stock honda studs? (ladysman)
ttt
Old Feb 17, 2003 | 12:44 PM
IntegD's Avatar
New User
If this is strictly a poll type question, the only thing I can add is that I use the stock honda studs and fasteners. Removed stock exhaust manifold, dc header, jdm header, and maxrev man numerous times, no probs yet.
Old Feb 17, 2003 | 12:45 PM
ekb18c's Avatar
stock
Old Feb 17, 2003 | 01:13 PM
boosted hybrid's Avatar
Default Re: Manifold Bolts, What is everyone using? ARP or Stock honda studs? (ekb18c)
Running grade 12, .75" longer than stock studs. I have problems with the nuts coming off all the time. I am going to double nut, double internal lock washer this time around.
Old Feb 17, 2003 | 01:20 PM
XES's Avatar
XES
Default Re: Manifold Bolts, What is everyone using? ARP or Stock honda studs? (boosted hybrid)
I am running the stock studs with stock nuts...and also had a severe problem wih the nuts coming off. Ever since I went to a double nut setup (still using the stock studs) none have ever come loose. I highly recommend doing this if you are having problems with loose nuts (and 2 will fit on the stock studs).
Old Feb 17, 2003 | 06:26 PM
ladysman's Avatar
Default Re: Manifold Bolts, What is everyone using? ARP or Stock honda studs? (XES)
ttt
turbomoe
Mar 28, 2007 11:14 AM
90Integra_Rs
Jan 12, 2007 08:39 PM
mrx
Aug 9, 2005 10:56 AM
Rain_man
Feb 4, 2003 11:27 PM
accordfreak
Dec 16, 2001 07:43 AM
