**Are APR bolts and studs necessary when turboing a honda????
would i have to change the bolts and studs when turboing a honda?? how much HP can the OEM bolts and studs withstand?
Re: **Are APR bolts and studs necessary when turboing a honda???? (hybrid901)
Not that many times apparently.
They failed on me after the 1st use.
Stick with stock.
Stick with stock.
Re: **Are APR bolts and studs necessary when turboing a honda???? (sgT)
stock is good...
just make sure you have a good quality torque wrench
have a good understanding on how to use them...
so there... now enjoy torquing around!
Re: **Are APR bolts and studs necessary when turboing a honda???? (jjgotboost)
May I suggest pulling the cams and retorquing the head bolts soon after boosting a few runs?
If the head bolts are still in spec fine, if not and they need to be retorqued, even better!
