after home many PSI do u need boost retard
Old Feb 15, 2003 | 08:08 PM
havok hybrid's Avatar
Default after home many PSI do u need boost retard
I just wanted to what everyone thinks or that is the common law behind psi and boost retard, for spark timing . im on 9 psi and i have no timing control.. just i have the distributor pull all the way back .. and i have my ecu custom chiped to retard .075 under load instead of advancing... what do u all think ...
Old Feb 15, 2003 | 10:37 PM
M-EJ1's Avatar
Default Re: after home many PSI do u need boost retard (havok hybrid)
Bump ^^
I'm also curious on hearing what the general rule is about this.. I'm running 6 psi on a greddy kit on a D16Z6 and I want to boost more but I can afford to plop down 750 bucks for a MSD 6BTM...
Old Feb 15, 2003 | 10:45 PM
CzanSOHC's Avatar
Default Re: after home many PSI do u need boost retard (M-EJ1)
.25 degrees per psi.
Also...BtM are only like $350 ish..
You can get a timming computer form jegs or summit for a little over $100
Old Feb 15, 2003 | 10:56 PM
falcongsr's Avatar
What is this crap?
Default Re: after home many PSI do u need boost retard (CzanSOHC)
really? thats it?
Old Feb 15, 2003 | 11:09 PM
b18cTurbo's Avatar
Default Re: after home many PSI do u need boost retard (falconGSR)
depend on your compression,octane etc..
my btm is set at .40-.50 after 5 psi
btw i have 8.8:1compression and we have 94 oct here
Old Feb 15, 2003 | 11:12 PM
CzanSOHC's Avatar
really? thats it?
Yes, my friend has taken his d16 up to 16psi w/ only .25 degrees...no detonation.
Old Feb 15, 2003 | 11:58 PM
YOUR FRIEND**.. what motor setup was it.. im on 9 psi.. ... and what turbo.. and what fuel.. ?... that would blown my mind if i could boost 16 psi on my sohc
Old Feb 16, 2003 | 07:37 AM
CzanSOHC's Avatar
Stock SOHC z6, Apexi turbo kit, Apexi V-AFC, 370cc injectors and missing link.
I told him he was crazy, but he pulled a 13.4 w/ z10 bars on a stock block at 16psi.
I don't recommend this at all.
Old Feb 16, 2003 | 08:02 AM
b16ahybrid's Avatar
They have the btm that you hook up to a stock ignition for about $169 and the one you hook up to an aftermarket ignition for about $180
Old Feb 16, 2003 | 08:20 AM
Diego Boost's Avatar
Default Re: after home many PSI do u need boost retard (b16ahybrid)
I was running .5 per/lb with the BTM before I got the Hondata.
[Modified by 99GSRT, 5:21 PM 2/16/2003]
Old Feb 16, 2003 | 09:14 AM
B18EG6's Avatar
Default Re: after home many PSI do u need boost retard (99GSRT)
This is distributor timing, right? and with hondata, it can do this on its own, right?
Old Feb 16, 2003 | 10:46 AM
Default Re: after home many PSI do u need boost retard (B18EG6)
Correct.
Old Feb 16, 2003 | 11:02 AM
JT's Avatar
JT
Bump ^^
Just curious, if you are willing to spend $750, why not doing it right and get yourself a S100 or S200 with boost? It's a much better way to spend your money, not to mention it gives you more control over fuel and ignition timing and other various settings such as rev limit, vtec point, open loop point. etc.
[Modified by JT, 1:55 PM 2/16/2003]
Old Feb 16, 2003 | 11:10 AM
tegasaurus's Avatar
yeah... to risk his motor like that on 16 psi for a 13.4 time slip doesn't seem all that great. if it was a 12.4 then i'd say well it's only what a $400 motor? nice times... but a 13.4... common
Old Feb 16, 2003 | 11:37 AM
TurbothisLS's Avatar
i've heard just to pull a little timing and you'll be fine until 10 psi
after that get the BTM or some other form of boost retard
Old Feb 16, 2003 | 07:37 PM
DIRep972's Avatar
Smarter than you
depends on the octane level gas u use and the compression ratio of the motor.
u can get away w/ stock timing up to a point. and then u might have to retard more and more as the boost goes up. and then theres a point where u have taken too much timing out which can be dangerous as well.
but.. .75deg retard per psi seems to be a good place to start
.5 deg retard/psi it still conservative but will make more power
.25 i would only do up to 10psi then i'd take out more.
if u look at the people tuning stock honda motors successfully they seem to take the higher boost/lesser timing approach. It has worked well on my car so far. running .7deg retard/psi
[Modified by DIRep, 8:39 PM 2/16/2003]
Old Feb 16, 2003 | 07:40 PM
swrdply400mrelay's Avatar
What were his trap speeds?
Old Feb 16, 2003 | 07:43 PM
wickedxboi's Avatar
Default Re: after home many PSI do u need boost retard (DIRep)
can anyone help me?
how much would i need to retard for 7 psi with a b18b and rev hard set up(to4e)?
7 x .25=1.75 degrees?
im a noob at timing.
Old Feb 16, 2003 | 07:48 PM
DIRep972's Avatar
Smarter than you
Default Re: after home many PSI do u need boost retard (wickedxboi)
can anyone help me?
I ran stock timing at 7psi w/ b18b and t04e. it ran great for a year. then i got hondata and turned up the boost more. but if u want to play it safe yeh .25deg retard up to 8psi would work nicely/.
Old Feb 16, 2003 | 08:08 PM
b16ahybrid's Avatar
not to hijack your thread but what about a stock b16a runing 9psi with t3t40E .57 trim .63 ar, gs-r ecu...
rite now i'm runing 12 degrees.....would 14 degrees be ok?
1990hondaHF
Oct 26, 2010 06:36 AM
miro_gt
Sep 19, 2005 02:17 PM
AznInvasion
Dec 12, 2004 04:14 AM
MarkAngelo
Sep 30, 2004 05:12 AM
willyboyK20
Oct 30, 2002 09:50 PM
