greddy profec b settings?
Old Apr 28, 2004 | 02:08 PM
AznInvasion's Avatar
Default greddy profec b 2 settings?
i need help setting my profec b i have no clue how to use it. i been messing with ist and when i boost at about 8psi it cuts off for some reason. do i have a setting set to high?
i am tryin to boost 10psi does any1 have a setting for that?
Old Apr 28, 2004 | 02:59 PM
Nextelbuddy's Avatar
Default Re: greddy profec b 2 settings? (AznInvasion)
here ya go. i dont know of any way better to explain it:
if you have a 5.5 psi spring then the max you can boost is found out by this:
5.5 psi x 2 = 11psi take half of that which is 5.5 and add it to 11 psi which = 16.5 psi.
so the max you can boost is 16.5 psi that is your wastegate springs limit for full boost.
so on this greddy profec b the first setting is changed just by turning the ****. the range is from 0-100 percent. this can be interpreted as a percent of yout max boost which is 16.5 psi ok? so say you want to boost 10 psi for example.... you need to calculate what percent of 16.5 = 10 psi. so if 0 % = 0 psi then that means 100 % = 16.5 psi right? so if you want to boost 10 psi then you need to find out what percent of 16.5 psi = 10 psi......
so we discover that 61 % of 16.5 psi = 10.065 psi thats close enough.
set your SET boost ( turn the ****) to 61%
leave the gain @ 10 for now (play with that later to help if it spikes)
now the 3rd setting SETBOOST (setting right after GAIN) this is read in PSI. so if is displays 103 you can interpret that as 10.3 psi ok? and you want this setting set as close to your very first setting of 61 % which is also known as 10 psi.
so since your first setting is @ 61% AKA 10 PSI then you would probably want to have your 3rd setting SETBOOST set @ 90 or AKA 9.0 psi.
hope that helps and remember that this is for a wastegate spring of 5.5 psi
if yo have a different size wastegate spring find out the MAX limit by using the procedure mentioned first above in my post and then figure out everything else accordingly
Old Apr 28, 2004 | 03:24 PM
Default Re: greddy profec b 2 settings? (NextelBuddy)
thanks but i juss tried that out and i keep boosting spiking. when it hits 8psi the car shuts off. i know my gauge aint off cuz i was running 2 5 6psi earlier. i am getting fustrated and thinking about getting a MBC now even tho i like my profec.
bluebullet's Avatar
FINALLY, an easy to understand explanation of this EBC. Thanks NextelBuddy!
Old Apr 28, 2004 | 03:32 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AznInvasion &raquo;</TD></TR><TR><TD CLASS="quote">thanks but i juss tried that out and i keep boosting spiking. when it hits 8psi the car shuts off. i know my gauge aint off cuz i was running 2 5 6psi earlier. i am getting fustrated and thinking about getting a MBC now even tho i like my profec.</TD></TR></TABLE>
well me and about 4 other people have ried this and it does work.
make sure your vacuum hoses are connected right!!!!!
the COM sideof your solonoid shoudl go to top port of the wastegate and the NO side should be TEEd intothe vacuum line going fromyour turbo compressor to the side port of the wastegate..... make suire you dont have any broken vac lines or any leaks.
when i tried the settings i mentioned above the first 2 times they didnt work and i got really frustrated and couldnt figure out why until i got thevac hoses right and even then it still didnt work because i found a cracked VAC hose.
if you usethe settings exactly as above with the VAC lines done the proper way with good vac lines then you shouldboostexactly what you want.
remember you CANNOT boost below your stock wastegate spring (if you havea 7 psi spring you cant boost below 7 psi )
good luck
Old Apr 28, 2004 | 03:35 PM
turbo*s2k's Avatar
Car shutting off! That's not good. What kind of EMS are you using? Any check engine lights?
Old Apr 28, 2004 | 04:54 PM
Default Re: greddy profec b 2 settings? (TurboChrgd_Civic)
i am running hondata s200 well the car doesnt shut off. when i reach 8psi around 6k the boost juss cuts off and it goes back to normal.
Old Apr 28, 2004 | 05:01 PM
could be boost cut. my tuner put a 15 psi boost cut on my hondata when he tuned it and never told me. and when i over boosted a couple times the car fell flat on its face. i got scared until i found out what it was.
Old Apr 28, 2004 | 06:45 PM
yeah that might be the problem i hope it is
Old Apr 28, 2004 | 07:22 PM
1fstevo's Avatar
New User
That's strange....
I have 1bar spring in my wg and all I can turn up max is 25-26 psi.
By your calculation, I should be maxing at 45 psi.
Old Apr 28, 2004 | 09:37 PM
turbo*s2k's Avatar
yup, sounds like a boost cut...
Old Apr 30, 2004 | 09:14 AM
bluebullet's Avatar
ok, on the solenoid. do you plug the unused port or leave it open?
Old Apr 30, 2004 | 09:20 AM
Default Re: (bluebullet)
any1 want a profec b?
Old Apr 30, 2004 | 09:44 AM
Default Re: greddy profec b 2 settings? (Evo Hybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evo Hybrid &raquo;</TD></TR><TR><TD CLASS="quote">That's strange....
By your calculation, I should be maxing at 45 psi. </TD></TR></TABLE>
check your spring and make sure its the right one.
also check and see if you have any leaks. if there are any kind of leaks that will cause you not to boost higher as well.
and blue bullet the unsed port onthe aolonoid leave it open dont plug it up
Old May 4, 2004 | 07:00 AM
TurboBumblBee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NextelBuddy &raquo;</TD></TR><TR><TD CLASS="quote">
good luck
right now im running my turbo off the tial wastegate w/ just the spring it boosts to about 8psi so im guess i have an 8psi spring, correct or not???
i have the turbo compressor line blocked off because im running a vacuum manifold right now, and ive read that a vacuum manifold off the brake booster will give you better vacuum signal then the turbo, is that correct?? and since i have it configured like that is it ok to run the vacuum lines like this, * COM side of soloniod to top of tial wastegate, and then NO side of soloniod to the vacuum manifold? and then leave the the bottom side of the wastegate hooked up as is to the vacuum manifold?? thanks for the help i would really like to get this EBC hooked up so turn the boost up..
Old May 4, 2004 | 07:55 AM
allmotorteg_96's Avatar
Default Re: greddy profec b 2 settings? (Boostfedb18c1)
how much r u asking for the profec b
Old May 4, 2004 | 09:35 AM
Default Re: greddy profec b 2 settings? (allmotorteg_96)
i paid $310 for this shipped so best offer takes it i dont need it nemore
Old Nov 4, 2004 | 07:43 AM
RNPoo7's Avatar
I have the same problem. I have a .6 bar spring in 38mm tial wg so i can't boost less than 9 psi, right? yet i'm boosting 6-7 psi max.
I have a vacumm manifold as well but havn't hooked it up yet.
Is this the correct wiring methods?
COM goes to top port of wastegate and NO goes to vacum manifold?
Also if that's true, what's the purpose of the side port on the wg?
Old Dec 12, 2004 | 04:14 AM
B16CRXT's Avatar
Default Re: greddy profec b 2 settings? (RNPoo7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RNPoo7 &raquo;</TD></TR><TR><TD CLASS="quote">I have the same problem. I have a .6 bar spring in 38mm tial wg so i can't boost less than 9 psi, right? yet i'm boosting 6-7 psi max.
Also if that's true, what's the purpose of the side port on the wg?</TD></TR></TABLE>
Bump, I want to know this too.
blackeg
Jun 20, 2011 12:14 PM
Metal Head
Mar 23, 2007 03:09 PM
Drew Peacock
Sep 5, 2004 10:36 PM
integ2
Jun 15, 2004 06:44 PM
99lspwr
Mar 18, 2004 02:07 PM
