after home many PSI do u need boost retard
I just wanted to what everyone thinks or that is the common law behind psi and boost retard, for spark timing . im on 9 psi and i have no timing control.. just i have the distributor pull all the way back .. and i have my ecu custom chiped to retard .075 under load instead of advancing... what do u all think ...
Re: after home many PSI do u need boost retard (havok hybrid)
Bump ^^
I'm also curious on hearing what the general rule is about this.. I'm running 6 psi on a greddy kit on a D16Z6 and I want to boost more but I can afford to plop down 750 bucks for a MSD 6BTM...
Re: after home many PSI do u need boost retard (M-EJ1)
.25 degrees per psi.
Also...BtM are only like $350 ish..
You can get a timming computer form jegs or summit for a little over $100
Re: after home many PSI do u need boost retard (falconGSR)
really? thats it?
really? thats it?
Re: after home many PSI do u need boost retard (CzanSOHC)
YOUR FRIEND**.. what motor setup was it.. im on 9 psi.. ... and what turbo.. and what fuel.. ?... that would blown my mind if i could boost 16 psi on my sohc
I told him he was crazy, but he pulled a 13.4 w/ z10 bars on a stock block at 16psi.
I don't recommend this at all.
Bump ^^
[Modified by JT, 1:55 PM 2/16/2003]
i've heard just to pull a little timing and you'll be fine until 10 psi
after that get the BTM or some other form of boost retard
Smarter than you
depends on the octane level gas u use and the compression ratio of the motor.
u can get away w/ stock timing up to a point. and then u might have to retard more and more as the boost goes up. and then theres a point where u have taken too much timing out which can be dangerous as well.
but.. .75deg retard per psi seems to be a good place to start
.5 deg retard/psi it still conservative but will make more power
.25 i would only do up to 10psi then i'd take out more.
if u look at the people tuning stock honda motors successfully they seem to take the higher boost/lesser timing approach. It has worked well on my car so far. running .7deg retard/psi
[Modified by DIRep, 8:39 PM 2/16/2003]
Stock SOHC z6, Apexi turbo kit, Apexi V-AFC, 370cc injectors and missing link.
Re: after home many PSI do u need boost retard (DIRep)
can anyone help me?
how much would i need to retard for 7 psi with a b18b and rev hard set up(to4e)?
7 x .25=1.75 degrees?
im a noob at timing.
Smarter than you
Re: after home many PSI do u need boost retard (wickedxboi)
can anyone help me?
not to hijack your thread but what about a stock b16a runing 9psi with t3t40E .57 trim .63 ar, gs-r ecu...
rite now i'm runing 12 degrees.....would 14 degrees be ok?
miro_gt
09-19-2005 02:17 PM
MarkAngelo
09-30-2004 05:12 AM
